Hey guys, as the name suggests i was wondering what are the negatives on driving with warped rotors. My rotors have been pretty bad for a while, and didnt get them replaced since i was either tight on cash or simply didnt have the time to get them fixed as i needed the car for university. The skyline vibrates like crazy when braking from around 100ks +, and has moderate irretating vibrations under normal driving. Its clear the rotors are fked and i already know that braking has been tremendously compromised, but what i want to know is, are there any other factors that need to be looked at once i do replace the rotors. For e.g. would wheel bearings need to be checked? etc..
Also ive decided to get slotted rotors to avoid having this problem again but was wondering what pads i should use. Are pads the main cause of warped rotors? I realise some pads are harsh on rotors and wear them out quicker, but as long at they dont get warped and provide smooth braking every time then im willing to sacrifice durability for performance. I just hate when the rotors get warped. So yea any help will be most appreciated!
Cheers
https://www.sau.com.au/forums/topic/412518-consequences-of-warped-rotors/
I was planning on getting them machined however its been around 10000+ks since the vibration started and its only gotten worse, im pretty sure its warped since this started the day ive been braking at 100ks+. Ive already purchased 4 slotted rotors but still thinking of what pads i should get. I heard ebc make good brake pads but i feel they might be overkill since i dont take the car to the track.
Just an update, i jacked up my car and spun the front left wheel and i hear this scraping noise, it appears during the 1st quarter of the rotation (in other words the noise isnt present during the full rotation). It sounds like a grinding noise and its present on both sides of the wheels, drivers side sounding slightly more harsh. However when i pull the wheel towards me and turn it, the noise disappears. Could this be the bearings? or just the warped brakes scrapping across the side. If it is the bearings, whats the consequence of changing them at a later date?
Cheers for the quick responses, and i will be sure to check the tie rods and bushes, ill get my mechanic to check them as well. So far i regret not changing the brakes sooner.
Seriously, rotors pretty much don't warp. You have to cook the crap out of them to get them to do it. As you have been advised, it is almost always pad binder deposition onto the rotor, and this can be removed by a hard thrash/rebedding procedure or with emery paper.
Slotted rotors are better at rejecting the binder material, not better at resisting warping.
Wheel bearings do suffer from the shuddering, so yes, consider them when you have the car apart. Besides which, they are old anyway, so will possibly be stuffed. Skyline wheel bearings often are completely buggered and don't show much sign of it.
I see, yea i highly doubt i cooked the crap out of them so yea its too late since i already ordered the rotors. But im still unsure of what pads to get, im actually confused since my car is a non turbo so i dont know which pads would fit, all i keep finding is benedix general use pads, theres no higher performing pads anywhere unless i pay retail at the mechanic which is insanely high price. From my knowledge r33 non turbo 1996 has single piston caliper? am i correct? If i do choose to go with standard brake pads, how will they perform under heavy driving/braking compared to the more expensive pads, do they just get shredded easier or do they melt?
Take a pad out. Take a photo of it. Put the pad on a piece of paper and trace around it, then mark the dimensions on that tracing (height, width, etc). Send the above to gslrallysport. Ask for street pads.
If you were after a retail solution I'd just suggest Bendix Ultimates. They are certainly not the best pad out there, but they do perfectly fine on a street car. I used them for many years, and would again. There are a number of more aggressive options available these days that are more interesting, but Ultimates still work. Anyway, Greg at gsl will be able to guide your pad choice from what he has available, and he will have something available.
cheers
cheers
Cheers mate, ill go for the benedix then! =) Im pretty sure they are similar to ferodo pads as well, anyways got another dilemna, this one really pissed me off, turns out the rotors i bought was for turbo charged skylines (or n/a skylines with 5 studs), so they require 5 studs while my car supports 4. Is it possible to drill 4 different holes so the rotors will fit?? Its so stupid cause i purchased the rotors according to dba's database which says that the r33 gtst has the same rotor as the r33 gts25 (dba 4000 series). After doing a bit of research turns out the gts25 uses 280mm rotors as opposed to the 296mm found on gtst. You reckon if i get the rotors drilled it will work with my calipers?
Cheers
No way in hell. They'll be the wrong thickness, and of course, the wrong diameter. Return them or sell them on. Then contact gslrallysport.
Alright will do, Still dont understand why their database gave me wrong rotors =='
Anyways cheers mate.
Because the DBA database is shit. It's what they decided/guessed goes on each car - not information from the manufacturer.
Yea i agree with you there, got the rotors returned, i couldnt use any other disc manufacturer as a reference, cause they all required me to own a business and register or some shit. Anyways i got a refund which im happy with, im just going to get my current rotors machined as suggested, now i got 300 dollars to spare, might just do a service or something.
Cheers for the help.
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
