hey guys
selling off my project car r33 gtr i only really just bought it but have moved onto something else now and cant afford two projects
the shell will be up for sale soon, have to finish a few things on it first
the other parts are up for grabs now though
ALL PARTS LOCATED IN MACKAY NTH QLD, POSTAGE CAN BE ARRANGED
r33 gtr gearbox, recently rebuilt with new bearings.. has not been run since - $850
r33 gtr/gtst fuel tank, no pump - $100
r33 gtr nismo in-tank pump - $250
r33 gtr BC External Reservior coils, as new only fitted and moved 50metres - $1350
r33 gtr black oem front bar, good condition paint is scratched a bit - $500
r33 gtr/gtst greddy front strut brace - $125
r33 gtr/gtst oem rear brace, have two of these for sale - $100ea
r33 gtr carbon fibre grill with no symbol just mesh - $100
r33 gtr rear wing, carbon end caps - $350
r33 gtr front lights very good condition - $350
r33 gtr/gtst cusco hicas lockout bars very good condition - $250
r33 gtr cusco front swaybar - $250
r33 gtr moonface racing castor arms - $200
r33 gtr passenger seat, good condition - $150
2jz bottom end - freshly machined by jhh in brisbane
Manley turbo tuff i beam rods
Mahle race pistons 86.5mm
Arp l19 headstuds
Arp maninstuds
Acl race bearings
Machined/linished crank
Torque plate honed block
Gapped rings
Pistons, rods and crank balanced
just need to clean, check all bearing clearances and assemble - $5000
Random parts
AME TM-02 wheels, 18x10+15 all corners on 1000km old achillies 123s semis 265x35x18 - all very good condition no gutter rash - $2300
power enterprise 800cc top feed injectors 11mm x 6 in boxes with plugs, new - $600
genuine greddy type rs blow off valve vgc - $100
rochester 14mm 1200cc injectors x 4, never been used only fitted - $400
buddy club fixed back seat, has rail to suit s13/4/5. black with grey inserts for a normal sized person, has a small tear in the fabric other than that its as new - $450
sr20vet mazworx lhd intake manifold, no fuel rail as new condition just needs a throttle cable bracket welded on - $500
sr20vet steam pipe high mount t51r exhaust manifold as new - $200
s14 jic front strut brace, vgc - $125
s13 whiteline front swaybar good condition - $125
S14/15 K.L.S camber arms - $85
2jz exhaust manifold 3d flange ready to make a manifold - $100
thats it for now..
please contact me on 0413347774 or via pm
I live in mackay too mate, love those wheels just not sure how they'd sit on my R34, it's got pumped an flared guards, and 9" on the front is fine currently.
What's the chances of test fitting?
My car is out of action currently though.
Shell is now for sale... It wont be available for the next two weeks as im still in Brisbane
Info:
Front windscreen cracked
Steering coloum shaft will need to be replaced
Stripped interior, not one bit of wiring harness front to rear
Front guards modified as per picture
Custom dash reo bar made
Custom alloy dash made
Sound deadening partially removed - just the stuff i could get with dry ice.. Some still baked on like around the gbox tunnel
Front radiator support cut out - was planning on welding a couple tabs to it then bolting it back on via the tabs
Lower front chassis brace cut out and replaced with a piece of tube to give the radiator more room and be able to have the intercoler sit upside down and have its inlet and outlet very close to the intake mani and turbo for short piping.
Thats about all i can think of at this stage
It is a registerable car
The price will vary depending what you would want to come with it, in its base form:
No driveline just suspension arms minus the cusco hicas arms and swaybars
No wheels
No suspension
No frontbar
No lip
No wing
$1500
If you want it to come with other parts let me know via pm or phone call and we will sort out a price
I dont really know how to send a shell interstate so im going to go ahead and say qld buyers only
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
