Hey all,
So I've got the option to upgrade my exhaust to something a little more 'special' at what I consider a fairly good price. My car is a 1996 S2 M-Spec R33 GTS-T. I have access to a HKS Hi-Power exhaust however, it's only listed for the BCNR33 RB26DETT. As far as I'm aware the system is only cat back. I've tried searching and I can't find a definitive answer so...
The question is - Will a HKS Hi-power cat back exhaust listed for a BCNR33 RB26DETT fit my ECR33 RB25DET with no hassle ie - mounting points are the same etc..
I've read that the R32 GTS-T and R32GT-R's are interchangeable, is this this same with R33's?
https://www.sau.com.au/forums/topic/412784-bcnr33-exhaust-on-ecr33/
Thanks for that, a little reassurance is good to hear :D. Just didn't want to go and spend the money then realize I'd have to find a GT-R owner willing to buy it :rolleyes:.
How was the ground clearance on both exhausts and what brand? (just out of curiosity)
Ah thanks man. I was really looking forward to getting this new exhaust but when I spoke to the guy he said it's not going to fit because it's designed for the RB26DETT - even though it's just a cat back. I'm usually an impulse buyer however, this is a little much to take the gamble on unfortunately. I'm guessing each exhaust bends/welds look different from manufacturer to manufacturer. I tried comparing my existing exhaust to one the same as I was going to get. The mount brackets look slightly different on the cannon tip (ones really short ones really long).
Has anyone successfully fitted a HKS hi-power GTR exhaust to their GTS-T?
Catback wise GTR or GTST will be exactly the same. Mounting points are the same, Reason they're located differently is probably because one cannon is designed to mount at a different angle to the other.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
