Hey guys, just got a problem hoping someone can help me with it or point me in the right direction to get it fixed.
I have a rb20 with a turbo from hypergear, nistune ecu, injectors, front mount, full exhaust all the usual mods, when i rev it out from 1st gear to second gear in high rpm it bogs down/lag and then the power kicks back in once ur in second gear, its almost feels like u slam on the brakes inbetween the gear change. Uts getting really annoying and i dont know what it could be, i thought it could be the BOV, coz i had it blocked off so i thought it might have been the air going back out the turbo slowing the wheel down but unblocked it and it still does it, i also have the pipe that comes off the BOV just pointing into the engine bay, not back into the intake, its still a stock BOV aswell.
If anyone could help me out that would be much appreciated.
https://www.sau.com.au/forums/topic/412962-rb20-lag-bog-down-high-rpm/
Do you mean where the plumb back pipe connects into the intake pipe, it's not connected?
So you are sucking air into the turbo through the hole in the side of the intake pipe?
Air that is unfiltered and also not measured by the AFM?
This would be a problem me thinks...
The Bov plumb back pipe, it's not attached to the Bov right?
Is the other end still attached to the intake pipe between the AFM and the Turbo?
Have you blocked any of the open pipes?
Its just the normal stock BOV and the pipe that from the trumpet bit of it just goes to no where to the engine bay, it used to go to some pipe which took it back to the intake for the emision reasons, but since upgrading to another turbo i had to get rid of all that so that bit of pipe just vents to the engine bay, and no other pipes have been blocked either
Blame the tuner :P
Waiting on NIStunes reply. They emailed today. Hopefuly have a few answers tomorrow
send it through if you need a quick reply, have the tuning lappy at home tonight.
I also had this problem on the R33, happens the air doses backwards onto the AFM. It was fixed by relocating the afm into the cooler piping.
Definatey seems like the same issue, and to clear things up its not a lag issue, its a hesitation
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
