  • Replies 65
I have had similar issue's with the ebay use injectors. Up to 30% out on a pulse test. Cleaned and reflowed they came up fine.
Injector service guy thinks they put some form of lubricant in for storing and sending and the libricant isnt breaking down so getting clogged.
Yeah they do, Every injector should be tested out of the box.
Firstly, most manufactures put shipping wax in them to stop oxidisation.
Secondly, if they don't, then oxidising occurs and that needs to be cleaned out.
Its the complete failing of injectors after they have been used that is a common problem.
Particular injectors that are treated in certain ways cause them to stop working.
Also you have to be careful with fuels that absorb moisture out of the air. They can very easily cause congealing in the filters.
This is worst case......... If one of your injectors flows 10% less..... Bang goes your engine.
If the injector stops completely then there is no fuel to make the bang to case any heat, so no dead engine.
Edited by HYPED6
seems like im on the right path....
a mate has some "bosch indy white" 1600cc injectors, they are low impedance/11mm top o-ring so should be direct fit, are they worth grabbing ?? his willing to give em to me for pretty cheap (of coarse im going to get them ultrasonicaly cleaned and flow tested before install plus new o-rings)
A true friend wouldn't do that to one of his mates
So even though they are listed as "cleaned and flow tested" it's best to get them sent out locally and cleaned again
Herd the new deatschwerks rb26dett injectors are good too
Even just tested. If they are ok, don't clean them unless you want too.
Its much easier doing that than pulling an engine out to replace a ring land.
Edited by HYPED6
Indy blue and whites are rubbish to tune with. I really don't think people know just how good the latest ev14 style injectors are. I wouldn't consider anything else if your looking at 1000's or above.
yeah its funny we all used to used them now i hate them... :P
Yeah there is a bulletin floating around from bosch saying the injector filters should not be used in E85 applications unless they are constantly monitored.
We find only the cars which sit for long periods between race events get congealing but it depends on setup, those with stupid over the top fuel systems (and super hot running engines like the real late model stuff) seem to suffer the worst as the extra heat in the fuel makes things worse.
The 2000's are still fine. You just need to look after them.
We have one car that is maxing them out with 130 PSI fuel pressure............ We are just going to fit another 2 injectors and keep tuning.
How ever we are looking at alternatives at the moment. Preferably something about the 3000cc mark.
The 2000's are pretty hard to beat at the moment.
I see you have joined the dark side Mike lol..
hahahah yeh i think he has alex, i dont wanna give inn, dos anyone know what kind of gains il get outta e85 on gtss twins??? lol i dont think its worth my while. making 320rwkw on 17-18psi now and going back up for some touch up so may get 330kw if im lucky. . im not power hungry, just very curious. lol
Has anyone found any difference using a wider spray pattern injector with e85?
Cheers
Justin
I've always wanted to tried the evox ev14 injectors as they are dual spray, only problem is they are only around the 550cc mark. You can get whatever spray angles you want if you have a good contact at Bosch motorsport. But like some of the coils I've priced you will pay through the ass.
I've made over 350rwkw, on multiple xr6t's, on the Bosch 968 440cc injectors on 98oct fuel but both alpha and delta angles for that head are perfect. That was on a fairly conservative dd dyno. That's a bsfc of around 0.4 which is off the chart compared to most engines!
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
