Big Brake Group Buy - Skyline / Silvia / Stagea / Wrx / Evo / All Makes/models
  • Replies 143
im in for front kit 356mm in purple for r32 gtr
would be keen on the rear set pending price confirmation
re: pads, ferodo ds2500 better option or the d2 street/race option? car to be used primarily on street
Honestly the street D2 pads are fine for street duties 100% :)
Added :)
(will confirm rear pricing when i can)
Street pad was fine in my R33 GTR for hill runs and similar @ 360rwkw and lots of traction. Long as you don't ask 10/10ths for 10mins+ straight /w heavy braking, you'll be very happy :)
Put me on the list for sure for the 356mm front kit for my 32 gtr with the black anodized caliper and sport pad with the rear kit also. Plus I read you need a kit for the hand brake for the rear calipers I'll get that too!
Kit for the hand brake... I shall investigate this also :D
I wasn't aware it was needed - will follow up, likely in 8-10 days or so once we all get back from SAU Nats :)
I'm pretty interested aswell, can you get me a price on the 356mm rear for 32 gtr aswell when you have time. Cheers.
About the handbrake issue, the way I read it was that you will only need a hydrolic handbrake if you want to use this setup for drifting. Otherwise the calipers work like normal. Maybe I'll read that again....
I read the same thing. Standard handbrake setup works fine with the D2 rear kit, as long as you're not using it for drifting. If you are, you need a hyraulic setup and second caliper.
I don't have a handbrake, I have a foot brake. So no funny business in the whale.
Ok then fair enough I'm sure I read the rear kit is 304mm and requires the kit to make it work properly and it's about $200 but if I don't need it then even better.
Done!
Im off to SAU Nats, back in a week and will then work on pricing for rears with Import Monster & Andrew from D2
Cheers fellas!
in the mean time i can help with enquires about the product, i cannot confirm any prices because this is to do with Import Monster.
As i said earlier - same pad size as the AP Racing caliper in the 356mm size, I think the code is AP5555 from memory.
I ran the 356mm kit on the front only - without rears. It didn't affect the ABS at all as Skylines are far more front bias so rears are less important.
As for how the kits compare - They are no $7,000 Alcon/AP kit (which they are based off)... But for $1800 - a saving of $5200 - you can't expect it to be identical, but i can tell you it's near enough having driven a mates GTR recently who has a 356mm Alcon kit. I couldn't say there was a difference.
Pad/rotor material plays more of a part in that anyway.
There were plenty of cars @ WTAC for example with D2 or K-sport brake kits on them, all working fine :)
Don't want to interfere here, but Alcons don't have to be expensive http://www.jdl-brakes.com/special-offer-alcon-adv-extreme-brake-kit-front-and-rear-nissan-skyline-r32-r33-r34-gtr.html
Maybe they are not such cheap as D2, but I'm pretty sure quite similar.
