Big Brake Group Buy - Skyline / Silvia / Stagea / Wrx / Evo / All Makes/models
  • Replies 143
For all of those wondering about caliper clearance, I just did a little measuring and while these are not 100% perfectly precise (due to me being unable to measure the D2 while mounted on the car, just dummied up on the bench) - so they're give or take a a millimetre or so
Factory BNR32 GT-R caliper protrudes approx 40mm past the disk mounting face where the wheel bolts up
Factory BCNR33 GT-R/34/V-Spec BNR32 Brembo caliper protrudes approx 40mm past the disk mounting face where the wheel bolts up
The D2 8 Piston caliper with 356mm disk protrudes approx 33mm past the disk mounting face where the wheel bolts up
This means that purely from the point of view of clearance to the back of the spokes, with the D2 you actually gain around 7mm of clearance.
Now the only complication that we bring into the equation is that these calipers will sit out further from the hub than the stock ones, so if your spokes taper back in aggressively, close to your stock calipers than this will reduce the clearance available. Very few wheels do this. So long story short - if you have 18" rims and they clear your factory brakes, be it Brembo or sumitomo 4 pots, you can be reasonably sure they will go over these brakes :)
And the reason there is more clearance for the D2 calipers compared to stock, even though they are physically much larger over all is because the materials used in the construction of the D2 are superior and able to provided the stiffness required to prevent caliper flex, while using less material. Stock calipers are a cast construction and require a lot more bulk to provide the same level of stiffness.
Still can't believe more people have snapped this group buy up!! Need some more people so we can get the first sets out. Next years track days are approaching quick.
Once we have 10 sets - will get those sorted out.
So ONE MORE, and you guys will have presents sometime late Jan most likely - tell your friends! :D
Ok let's get this thing moving, nismoid put me down for a rear kit as well, I've come out under budget this month so I've got more play money :D, rear kit 96 R33 GTST, street pads and yellow calipers please.
Cheers
Excellente!
I'll PM people later tonight with further information and what not (in the PM we already have going) :)
One other guy onboard to - will update and PM everyone with acc info about 10-11pm tonight!!!
So get the EFT's in fast, and we can hopefully get the order sorted before xmas :merli:
If you are last min and want in for this shipment, post here ASAP
PM's with more info sent to everyone.
Last chance to get in on the first run before the order is hopefully put through on Fri :)
Hey mate,
Looking at some black-anodized D2 front calipers. Going by what I've read above seems 330mm for 17" rims or 356mm for 18", this correct? Have an R32 GTS-t so not sure on what the details required would be - but definitely interested.
EDIT - remove. Just realised the date of last response was on the 19th December - apologies.
Does anyone know if work xd9's in 18x10 +18 will clear the 356mm kits on a 32 gtr?
grab a ruler and check it with info Aaron has posted previously if u have stock brakes at the mo
I'm running similar spec rims and going with 356 kit
Cheers mate would love to measure it but i havent bought the wheels yet, lol
Got 17's on there at the moment but they will have to go as soon as i get the new brakes.
Hey Mate
can tell you 100% the XD9 in 18 x 10" +18 will clear the brakes, or I'll refund you no probs. They have loads of brake clearance :)
Cheers
Aaron
Hey Mate,
you're spot on. the 356mm ones need 18" min, the 330mm will go sweet under 17"s
The second round of this group buy will be cranking up very shortly I believe, so you are not too late if you want to jump on board :)
Cheers
Aaron
Hey mate,
Hey Mate
Cheers
Aaron
Thanks Aaron, looks like ill be ordering the wheels now then.
Confirmed the order has been placed after talking with Aaron @ Import Monster
I've started a thread for the 2nd Round as I'm getting PM's from people asking if it's closed, so see here if you want in on ROUND 2:
http://www.skylinesaustralia.com/forums/topic/417253-big-brake-group-buy-2-skyline-silvia-stagea-wrx-evo-all-makesmodels/
Update is above mate, that was 10 days ago. Order placed, waiting for completion and shipping (order was placed days before i posted, just had no internet to update over NYE period).
Once i know more, I will post for everyone. It does take a few weeks for the orders to fill. :)
Yep order was submitted to D2 in the first week of Jan, after they returned from their New Year holidays. From experience, it usually takes around 2-3 weeks for them to complete an order of this size and then around the same again to get shipped, clear customs and quarantine and land in the shop. I'll keep Ash updated as we reach each step :)
Hey Guys,
just an update, manufacture of the kits will finish this week and the freight has been booked. The ETA for the ship to arrive is approx 13/02 and it would usually take 3-4 days to clear from port and customs and arrive to our shop.
Cheers
Aaron
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
