Why is it a waste of money? You could save me some cash here.
Stock blocks have been proven reliable well past 800whp, so unless your building a dyno queen or drag monster... why bother.
  • Replies 61
Thanks for all the suggestions. (
Coming away from this and talking to him, I think there is two ways forward for his needs
1. Buy one of the cars already built for $20K, sell his car with damaged engine to somoene who wants to customise a rebuild
2. Get the bolt ons and talk to a builder about what is possible with the rest of the build.
2860-5/7 turbo's $2500
Haltech inc boost controller $2000
Jun Fuel pump $400
IDC1000 Injectors $1000
Fuel rail to suit injectors $350
Fuel regulator + guage $100
Apexi air intake $700
DFI radiator $700
Intercooler $1000
Metal intercooler piping kit $400
Inovated air/fuel guage $200
Oil cooler + relocator with thermostat $1500
Engine in/out $2000
Total $12850 + $7K rebuild
Unsure on what exhust he has, so dumps etc would likely be needed.
Jun Fuel pump $400
DFI radiator $700
Intercooler $1000
Engine in/out $2000
A few things
1 don't need the apexi intake, stock air box is fine
2 haltec ecu's are rubbish compared to what else is out there
3 you can get a twin entry rail to suit those injectors for less then $150,
4 you dont need big injectors for -7 turbos so no need to change rail
5. Fairly certain there's koyo radiators going for less then 600 (not that that set up needs a big radiator)
6 there's heaps more but I can't be bothered
Thanks for the reply Joe
Please identify the better ECU please and why it is better, most in Aust know the Haltech and can use it well. Vipec is good but not as supported. I'm not up-to-date on the latest advancements.
Are you basing the rest of your comments on a 300kw car? Air box and injectors are limiting at above 300kw I understand. If anything i'd expect the intercooler to be the first thing to be cut.
He'd prefer to get something that is a bit over kill then be on the limit, particularly things like injectors.
Airbox and injectors are not limiting to 300rwkw.
Airbox will do 400rwkw, it's been proven time over. $700 saved.
Stock piping is fine, doesn't look great, but stops compressor surge. $400 saved
Injectors will do around 300-320rwkw, which is what -7s will make max. So you save not needing rail/injectors/FPR etc. $1400 saved
Intercooler is also totally fine. $1000 saved
So $3500 saved already from things you simply do not need, and never will :)
I've talked to my tuner about different ecu's, Haltechs are not as good as others for a number of reasons and are over rated. the better ecu's out there include Link G4, vipec, autronic.. After talking to him I'd still get an apexi pfc over a haltec
I'd suggest finding a tuner that does one of these, I'm using the link and am often complemented on how smooth the car is to drive, even with the extensive mods I have
My old set up was a 300rwkw set up and I didn't have half the stuff u have listed..
One thing I do suggest is upgrading your fuel pump to a new item nismo/stock what ever u want, and ensure it has plenty of volts to it..
A few things
This!
This!
I'd run with a Nistune or an APex'i PFC.
So... you haven't actually used a Haltech? what reason's did you tuner give?
I've used a vipec/link and Haltech in my car. IMO Haltech is an awesome ECU, as good, if not better then a Vipec. Would not hesitate to buy another Haltech.
Edited by wedge_r34gtr
Haven't used a haltech, have been right there standing next to the dyno when cars with haltechs have been tuned.. There's a reason my tuner charges extra to do a haltech and that's cause they are a pain in the ass, he has a standard to which a car needs to be before he lets a car leave.. And haltechs take a lot longer to reach that standard.. And he knows his stuff I assure u
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
