Hey all,
I'm currently working on a personal project to graphically document major rb series engine components, with the aim being a web page or java app that will aid people (mostly people newer to the mod scene) in locating key areas on their own vehicle.
I have browsed the forums and the net in general for pictures that meet my requirements but i have realised that for any kind of consitency i'm going to need custom photos.
What i am looking for is photos of assembled engines, more specifically a rotation of the engine taken at 90 degree increments (or 45 degrees if your feeling generous), including the top and bottom.
I'm hopeing to avoid having to hoik the engine out of my car to do a set for a 25det, so if anyone has an rb series block out and have access to a dig camera any pics would be appreciated.
if all goes well i plan to put it up somewhere for everyone to use if they like it.
PM me if you can help.
Go to JustJap or another import parts wrecker and ask. Tell them what your trying to do and I bet they will be happy to oblige. Especially Just Jap if you're a donator to the forums or a member of SAU NSW (hint hint) :P.
yeah im sure they would be happy, just credit them that you used an engine from them as reference. its also good for whoever lets you use their engine because people who look at your site can say "oh i can change that with this" and buy the parts from the wrecker
My Rb25det is out and in pieces on the floor ;)
It should be going back together within the month and could take lots of pics if you wanted.
I also have a 2nd 25 coming in a few days so i could take some pics of that but it needs to be cleaned up first.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
