you'd be surprised what you can do with a 4 door semi chop... apparently its VERY easy to do if you have a 4 door... hmmm might try to talk a certain $2 4 door R32 owner into it :P
And yes you get to keep the 4 door tail lights.
btw NATS = Nipon Automotive College... where you learn to race, maintain, design and build cars. The pics above and the ones they showed at autosalon are the works of all their students... if you thought their skylines were different wait till you see what they do with the other cars..
Also you'll note that the ute's back windoe is the stock R32 rear window, simply moved up. According to the students who built the car, they've cut the rear passenger section and seats out of the car and moved everything else forward. The rear doors were cut and welded into place, as was the bottom of the boot. The rest was then finished off with FRP (fibre reinforced plastic, or fibreglass as we know it) and bog sanded and then painted.
Oh and in case you're wondering the taillights of the oldschool skyline is in actual fact supra lights.
  • 2 years later...
All i know is it was a former 4-door, has a Toyota truck bed in it... made by Nats OSTY
oh actually i found some more stuff....
http://www.youtube.com/watch?v=fWDg06O_fhQ
ok i guess, my question is what are your thoughts...
"sorry if its a repost"
Edited by 4DoorWhore
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
