S A U - N S W Dyno Day! 8Th Dec @ Unigroup Windsor
Time for a dyno day and what better place than at the new Unigroup workshop in Windsor, Western Sydney!!!
Get your beast on the rollers!!!
When: Saturday the 8TH of December 2012
Where: Unigroup, Windsor, opposite Tyres plus 1/124 Ham St Sth Windsor NSW 2756.
What time: From 12PM lunch time!!
How much: $60
Food and drinks:
There will be a BBQ and softdrinks for lunch on the day.
Drink $1
Snag $2
If you are not entering your car in the dyno day and just watching,
or are near the bottom of the entrants list,
please park out on the side of the road as the complex can get quite busy!!!
Cheers!!
  • Replies 78
Do we rock up on the day and enter or is there a form?
Been busting to see how little power my car is putting out.
In saything that, I'm in.
Edited by FeZ25
We can put GTR 33-34's on the hoist at Unigroup to drop the front drive shaft :)
yep pretty much a 5 min job
should be able to make it, lets hope some of the big talkers show up with their "400 kw" cars
should be a good laugh :)
Haha....that's a good one :D
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
