Helmut Marko does not hinder Red Bull, insists Christian Horner
By Jonathan Noble Tuesday, April 30th 2013, 09:45 GMT
Helmut Marko's presence at Red Bull is a help rather than a hindrance to the Formula 1 outfit's ambitions, insists team boss Christian Horner.
Although Marko's outspoken views have often stirred up controversy - especially because of his close ties with Sebastian Vettel - Horner claims that Marko's Red Bull advisory role assists the F1 squad by giving it the independence it needs.
With the recent 'Multi 21' team orders row having prompted fresh intrigue about the management make-up at Red Bull, Horner argued that he is freed up by Marko's responsibilities with Red Bull owner Dietrich Mateschitz.
In an exclusive interview with AUTOSPORT, Horner said: "I have full responsibility for the operation of the team trackside and in the factory.
Horner interview: I'm here to win, not be popular
"I report directly to Dietrich, who has always been tremendously supportive. He sets high standards.
"Helmut has responsibilities elsewhere with the young-driver programme but he has no operational responsibility or input into how we operate as a racing team. He's an advisor to Dietrich, and he's obviously an experienced hand.
"Part of his role is that within the Red Bull corporate world, now that it's such a large company, he has enabled Red Bull Racing to retain its independence. That allows me to operate with the freedom to manage the business and manage the team how I see fit."
Although ultimate decisions on Red Bull's long-term plans are still down to Mateschitz, Horner says his relationship with the Austrian is on solid ground, and he has never had anything but full support.
"Dietrich is the chairman and a major shareholder, so of course I answer to him," said Horner.
"But he gives me the autonomy and he has a trust in me that I represent the team as well as I can, and he gives me very much a free hand to run and operate the team; to recruit, to operate the team the best way that I see fit.
"Of course I keep him updated. And of course with any major decisions be it on the drivers for example it will ultimately be with him.
"But he has always followed and backed the team whether that be an investment in capital expenditure, or be it in an engine change."
So.... Rip senna? No one?
About 30 mins ago aest time he was probounced dead 19 yrs ago.
Was he the best? I think he served 75% of what he clould. So take all the other guys into account at that percentage And yes he is!
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
