Perez is driving stupid in my eyes. He is just diving into spots he isn't going to win and then bitches on the radio that they should give up the spot
Glad I'm not the only one thinking that.
Alonso should've pushed him all the way out to the wall but instead he was penalized for avoiding an incident.
