If Merc keep improving they will be in the WDC battle.
Montreal doesn't really have any long corners to load up the rear tyres and overheat them. A few short sharp fast chicanes, some slow hairpins and high speed straights. The Mercs could be mixing it up the pointy end again this weekend...
Edited by hrd-hr30
Ferrari have revealed that Felipe Massa will use a brand new chassis at this weekend's Canadian GP following his shunts in Monaco.
http://www.planetf1.com/driver/18227/8756981/New-chassis-for-Massa
This weekend's Canadian Grand Prix will once again have two DRS zones after the FIA decided to "double-up".
The 2011 race at the Gilles Villeneuve Circuit also had two zones - one on the Start-Finish straight and the other before Turns 13 and 14 - but the sport's governing body decided to use only one last year as they felt overtaking was a bit too easy.
However, it will be back to two this season, but there will be only one activation point - the first zone is 55m before Turn 12 (Casino Straight) and the second is 70m after Turn 14 (Start-Finish Straight).
Both zones are shorter than the ones used during the 2011 season.
http://www.planetf1.com/driver/18227/8757808/Two-DRS-zones-for-Canada
I thought Canada had a abrasive service too?
Saw the interview with someone from lotus who said the surface is less harsh on tyres then previous races. Brakes are a bigger issue but technology has comefar enough in that area that its manageable
Mercedes referred to International Tribunal over tyre test row
An FIA statement said: "In the light of all the replies received and in view of the information gathered during this inquiry, the president of the FIA, acting as the FIA prosecuting body, has decided:
"To close the case as regard to Scuderia Ferrari Team considering that its participation in a tyre test organised by Pirelli in Barcelona on 23-24 April 2013 using for this purpose a 2011 car is not deemed to contravene the applicable FIA rules.
"To bring the case concerning the tyre testing session carried out by Pirelli and Team Mercedes AMG Petronas F1 in Barcelona on 15-17 May 2013 before the FIA International Tribunal because it results from the inquiry that the conditions of this testing may constitute a breach of the applicable FIA rules.
"The FIA International Tribunal is called upon to make a decision in compliance with the FIA Judicial and Disciplinary Rules."
http://www.autosport.com/news/report.php/id/107882
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
