Teammate comparisons in order of the percentage of points contributed by the number two:
4. Hamilton 62 vs 6. Rosberg 47 = 75.8% points and -2 positions
13 Ricciardo 7 vs 15 Vergne 5 = 71.4% points and -2 positions
3. Alonso 78 vs 7. Massa 45 = 57.7% points and -4 positions
8. Di Resta 28 vs 11 Sutil 16 = 57.1% points and -3 positions
1. Vettel 105 vs 5.Webber 57 = 53.3% points and -4positions
10 Button 25 vs 12 Perez 12 = 48% ponts and -2 positions
2. Kimi 86 vs 9. Grosjean 26 = 30.2% points and -7 positions
Massa ranks 3rd overall and best of the big 4 teams other than Rosberg at Mercedes.
All I can say is Lotus must be desperate for the money Grosjean has behind him!
Edited by hrd-hr30
    • Whilst the brewery had good beer, I didn't rate the pork knuckle, the meat was good, but, there was no crackling, the skin was just thick and chewy Will return at some stage for the beer, but, I will wash the beer down with chips Plus, no sauerkraut, in what world do people serve pork knuckle without sauerkraut, they did serve apple slaw with it, which was nice, but.......#sauerkraut the world
    • Wow yeah ok. Given how specific you are about your car, I'm very surprised you are happy to do that.  As a bare minimum, without having a wideband gauge in the car or running it up on the dyno to check mixtures, there is no way I'd do that to my car.  You beat me to it, was going to say just this.
    • Yeah - that's not true. Larger turbos flow more at the same boost. By definition. I've always found it funny when the claim of same flow same power because same boost is made. The turbine is larger, therefore will put up a lower restriction to flow at any given flow, cf the stock one. Hence, you need less boost to make the same flow through the whole system. Hence, when you have the same boost as before, you must have more flow. -5s are a pretty decent bit bigger than stock.
    • That's basically how I've been driving my R33 for a while now. GTIII-SS running wastegate boost. It makes no more power than stock because the turbos aren't flowing any more air than stock. Eventually though I need to fix this so it can actually drive as it should.
    • If this was my own car, I would pull about 5 degrees off the CAS, run a wideband, and if that seems ok, send it.
