lol.....
It may be just me but I feel for quiet some time that 'Fasta Pasta Nando's' is just reckless in F1? I'm so surprised he still in an F1 seat after all the reckless accidents he has caused????
Why? He can actually drive a bit when he isnt doing stupid stuff and he brings in masses of money to Williams. It is easier to stop a driver doing dumb shit than it is to make a slow driver quick. So they will keep him until either his money runs out or they can find someone faster (With money).
I think the key words here are the ones underlined in bold.
that is what its all about theses days!
ohhhh......and with out that financial backing......he certainly would not be in an F1 seat IMO.
Edited by Ants
He isnt looking at all like a race winner or even fast this year. That hat goes to the Finnish team mate
Yeah Bottas is beating him but neither look like race winners given the car isnt much chop. But the reality is nowadays you dont make it through the junior formula without bulk coin and even into F1 without backing.
Have a look at what rubbish aero has done to their share price.
http://quotes.wsj.com/XE/XETR/WGF1/interactive-chart
...and rubbish global financial systems. Though another le Mans win with their tech and the new green series next year all provide funding to Williams Engineering ... if not Williams F1.
Its a shame they had such a good car last year ... you wonder how much Toto and Gillan leaving rattled the ranks focus.
Think the two companies are under one listing on the German SX?
You never know how much influence any one person has on the car design or the business or if it just that the wind tunnel calibration is shit. See how Sam Michael is going at McLaren for example or how Ferrari went in the last few years.
no, that's what happens when FIA signs a contract with a tyre supplier permitting testing despite the sporting code banning it, then tells a team "OK, you can go to the test with the 2013 cars as long as Pirelli are running the test" and then backflips when other teams complain...
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
