am I right in assuming that if that happens, it'll be the first time the Scuderia have released then taken a driver back at a later date?
Gerhard Berger was the last to do that? Have to think about others, probably be stupidly obvious.
And so it is. Mario Andretti did a famous cameo in 82 after Villeneuve and Pironi destroyed themselves/each other. Also Clay Regazzoni.
Edited by djr81
Felipe Massa has revealed that he will not be at Ferrari next season, with his departure leaving the way open for Kimi Raikkonen to rejoin the team.
Ferrari has spent the last few days finalising its 2014 driver line-up, and it was widely expected that Massa would not be retained.
Ahead of a scheduled appearance at Maranello on Wednesday, Massa duly confirmed that he was looking for fresh opportunities in Formula 1.
In a message that was posted on his Twitter feed, Massa said: "From 2014 I will no longer be driving for Ferrari.
Analysis: Lotus ready with 2014 plan B
"I would like to thank the team for all the victories and incredible moments experienced together.
"Thank you also to my wife and all of my family, to my fans and all my sponsors. From each one of you I have always received a great support!
"Right now I want to push as hard as possible with Ferrari for the remaining seven races.
"For next year, I want to find a team that can give me a competitive car to win many more races and challenge for the championship, which remains my greatest objective."
http://www.autosport.com/news/report.php/id/109804
Did massa just grow a backbone or are Ferrari giving him a chance to leave with dignity?
Well bye-bye Massa! Nice guy, gave it a nudge and deserved to rob Hamilton of his WDC but his time has come
Shame be could not carry his form from late last year into this season...but alas, goneski. PLEASE DO NOT LET HIM END UP AT LOTUS!!111
Why?
Massa and Grosjean would be great crash buddy's..
Many lols would be had. :P
I cant see Kimi going back to Fezz when it was them that killed his interest in F1...but he wants a competitive car. Fezz want results and keeping Kimi motivated and Alonso happy doesnt seem to fit with the team . I suspect Kimi is using this all to push Lotus and perhaps even McLaren. Surely its Hulk going to Fezz
BBC say its a done deal http://www.bbc.co.uk/sport/0/formula1/24042352
"The Finn, who won the world title with Ferrari in 2007 but was replaced by Alonso at the end of 2009, has signed a one-year deal with an option for 2015."
Lotus have said they want Hulk if they lose Kimi.
Massa back to Sauber??? Can't see anywhere else for him.
So Ferrari look a bit silly now. Hopefully a front running car for Kimi but :)
Shame Lotus lost James Allison and couldnt confirm substantial financial stability in the team or that car with Kimi at the wheel could have been amazing next year
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
