Rules say stay off the track until all cars are off the track in parc ferme. Simple.
Two cars had to dodge the parked Ferrari on the exit of the blind corner.
Webber was running around on the race track in front of one of those cars who had to alter his path to miss both him and the Ferrari.
The other had to go off the track to avoid them.
A reprimand doesn't seem out of order at all.
Well, I will start passing the hat around now to cover the fines Webber is going to be handed at the end of the season when he drops some helis/burnouts in Brazil. It will happen.
I get the rules and what happened. I just find it a bit silly that it is a ten spot penalty for the next GP! And yes I udnerstand its because its his 3rd reprimand. I just went back and looked at the Bahrain clash with Rosberg and its a bit silly that Webebr chopping off Rosbergs nose after he awkwardly placed it up the inside into a disappearing gap and earnt Webber a 10 spot penalty.
Anyway... this is as silly as the fine that Hamo got back at Silverstone a few years ago hecause he dropped a donut or Alonso's fine in Spain the other year when he won!
Also seems the booing of Vettel is here to stay. I would rather it didnt happen but ultimately dont really have a problem with it. Commentators seemingly agree its part his dominance, part his perceived status at RBR but mostly what happened in Malaysia. I guess Karma is a b&$ch!
you would think that there would be mention of Alonso doing 100kph+ with mark there more of a reason to reprimand?
I see no issue with what they did. if they cant dodge an obstacle at 40 - 60 kph how the fark are they expected to when on the noise.
Yeah I was pissed at Webber's penalty until I saw the CCTV footage. That was dumb, stopping just around from a blind corner was dumb. Alonso should have pulled off the track. Webber shouldn't have played frogger with other cars on cooldown lap to get a lift. A reprimand for both drivers is justified IMO.
10 spots is a harsh penalty, Mark seems to cop it from all sides sometimes but it's a consequence of a 3rd reprimand so fair enough. tough luck, son. F1 should be held to the highest standard for all concerned, just because something happened in GP2 doesn't make it OK for F1 to lower its standards. Having said that, some leeway for sportsmanship and showmanship should be given. Schuey used to dance and sing a bit on the podium until some grand poo-bah got their nose out of joint, and drivers used to do a bit of a burnout to celebrate now and then. none of that happens, it's f**king boring yes sir no sir i have a really itchy spot on my forehead by the way did you see the nice big watch i'm flashing in front of the camera (massa is an expert of that move during post-race interviews).
I agree with burnouts at brazil until the tyres pop. it would be so worth it. f**k bernie and his increasingly shitty formula.
I have decided I am going to be one eyed on this! :) Plus, they can say what they want...the fact the FIA have come out this week and said drivers are not allowed to do it anymore tells you the tone of their concerns, irrespective of it being done off in tehy kitty litter or in the middle of the road. Thinking back did Alonso get a fine for collecting the Spanish flag a few years ago after winning in Spain?
I can understand there concerns. I mean hell if he were to fall off he'd be going straight under the rear wheels. The location was a piss poor place to do it and the penalty i think is fair. If they were to fine webber instead that wouldnt solve anything. I mean hell vettell recieved a $1000 fine (was it?) for 9km/h over in the pit lane. He earns that in minuites! How is that due punishment?
Thats like me recieving a speeding fine for $2.50 for 20km/h over out on the street. Shit idd speed around all the time! Ah its only $2.50. I'dd even pay in cash! :D
However that's not to say i didn't enjoy watching it happen!
The sports lost some of its original charm at least from the late 80's to early 90's. That happens of course and there's nothing we can do to change that. However as stated above im all down for f1 ring making on the pit straight! :D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
