Webber pitted for tyres, next lap Perez tyre exploded & Web got puncture so had to put straight away under safety car. The Sutil lost it after the restart straight into the side of Webber who then caught fire
i have to admit.. them korean girls didnt look half bad.
Hulk is a fkn champ driver, I loved how he just bewildered hamilton for 15 laps
If he doesnt get a good seat next year I will be dissapointed, also wtf happened with di resta.. He was so consistent and in decent postitions all of last year and first half of this year then BAM HAM MODE ENGAGED
Hulk's traction out of those corners was crazy good. To get back past hamo before the drs line and then drive off into the distance with drs open was just plain funny. As was the jeep trundling down the straight.
Rbr's bank account will be taking a battering with 2 cars going up in flames in 2 races. If it happens again I'd like to see Mark pull out some marshmallows and roast them on his car.
prolly would have been a different story if Mercedes had geared the car taller in 7th instead of him bouncing off the limiter with DRS open
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
