  • Replies 71
I am also in the ulleh group, sorry I meant ching chong, I mean yellow group.
WIll install pod filter in place of the factory airbox Saturday morning for maximum flutters ROFL
think cause i was so early in my rego like december last year i got first group :( should have held off :( oh well ill show up all the comadores and falcons for u guys lol
represent, make sure you get the flutters going LOL
Well had a great day, in the last session of the south circuit on the last lap she sprung a small coolant leak in the bypass cooling hose under manifold.
Great day good instructors best fun ive had with pants on. My first proper race track experience.
if you got your times recorded on the texi would love to see the results.
My quickest was a 32.23sec in the GTSt :) only got 4 runs.
awesome day, motorkhana was alot of fun, my quickest was 32.04, circuit was very good, had bit of brake fade on the hairpin and got in before the rain started
ran the car with stock actuator boost as a pre-caution in case i got carried away 1st time on track
both instructors were very good, heaps of information and pointers
+1
Had a great day - fun/non serious atmosphere, loads of variety of cars. Very nice BB BNR34 GTR in the last session.
Besides the "speed limit" I did manage to get up to a sneaky 140km/h down the back bit. Instructor was great - very informative and calm. Instilled a good level of confidence and level headedness. Motor held up fine - bloody over engineered the cooling system so the thermos didn't even switch on. Brake pads were the first thing to start to go, but only had a long pedal a couple of times over the sessions. Pity the traffic was so heavy. Would have liked to have at least one good timed session, but was stuck behind quite a bit of traffic.
Motorkhana times- I did 4 runs.
RWD: first lap - 33.82 then 31.82
Put the fuse back in so AWD
30.38 and best time of 29.67 before I pulled aside.
Got a bit of a round a of applause from the timing crew, so I don't think many were below 30 secs. Hope they put the times up, but don't think they were officially recorded. Only other sub 30 sec time I heard was an Audi quattro wagon. Wagon FTW!
All in all a great day!
good job, yah on my track runs my instructor said "that Sti infront isnt sticking to 100km/h, just go as fast as you can' so i managed about 135 up that main straight before the esses. was loads of fun, got to pass 3 cars in my 2 sessions.
The best pass was on a vt SS vommadore, all over him through the corners but struggled a little to keep up on staights but was waved through and left him behind on the next few laps. No brake fade the Bendix held up well. Just the slight issue of coolant but got her home no overheating at all. good old Skylines ;)
Yeah it was good fun. Rained during our track session so that made it pretty wild even with 4wd... Civic in front of me had a wild lift off oversteer spin after the sweeper down to the old turn 9; ended up off the track to the inside and not far off the wall.
Only got 4 runs on the motorkhana too and managed a 28.8 (got video of that run so I might post it up later - using the horn is key)
I did a 46 on my second last run !! haha
Was stuck on the spot and couldn't even get past the first cone, I said to the guy next to me this place is suddenly very slippery while I did like 5 donuts, clutched in and motor was still revving :/, throttle linkage must have gotten caught when I clutch kicked.
He said you better stop before we get in trouble, hahah he loved it
I am disappoint!
Blew a cooler hose off on the last session of the motorkhana and didn't realise till i went onto the track for the first session...so had to crawl around and make my way back into the pits to fix it. Coach was great though, (Bob) even helped me fix it. Went out again for the second sesh and lasted almost one lap before it popped again!
Fixed it once more and headed home...have now fixed the problem hose. Guess i should have done some more testing with the new cooler setup before hitting the track.
My quickest khana lap was 31.02. Pretty happy with that.
Gah! Beaten by a R34 GTR! Suppose thats ok ;)
Yeah, we were watching the last track session, and looked very slippery. Michael, I think your car is set up for drift! Had to creep round the turn near the pits to get around it!
edit- I reckon I could do that time if I had a handbrake. Have a stupid footbrake is useless, and I suffered massively for it.
    • Today, I'm a Breville BES920 tech, new triac board and new 3x way solenoid. Had overheating issues, home RCD tripping when it got warm, and the boiler stayed on when the machine was shut off. Also, usually 3x way solenoid chatter, this is the 3rd time I'm replacing it. Mind you, this machine is 9 year old and send it every day doing at minimum 3x double shots. When the in laws come over to took after my daughter, it will easily see 6x double shots in a single day. Tried to be somewhat compliant, crimped and then used a screw connector over the top. Would have preferred to use heat shrinks.   After all that, turns out all the overheating has damaged the o-rings to the steam tap as well. Ordered new ones, coming soon.
    • Still got it- First time checking sau in a while ahhaha
    • I don't know about that. I can hoon my R32 around - hard launches, high lateral Gs - with <<1/4 tank without any such shenanigans. This with the previous 040 and the current GSS342. I would suspect a fuel line problem. One of the hoses associated with the top of the tank perhaps.
    • This is amazing. Love that you’re giving the boys an intro to cars and off the screens. They probably have an insta for the car and build posts on TikTok for their mates.
    • It is.  Your car works fine with the tank full. If you drive like a Nana it works fine.  You give it a boot full with half a fuel tank, you get surge.  It 100% is a fuel surge issue. Maybe have a look at installing a Hydramat if you don't want to install a surge tank.  https://www.holley.com/products/fuel_systems/hydramat/
