Like I said above, the 6768 had no problems making power, we did not push it ... barely touching 18psi for the 500 awkw. Making the power down low is where we need it then winding up the boost to make the top end is the plan !!
500 awkw is enough to play with (to start with)... I've done about 8 laps in the car so far... 5 at Phillip Is with no power steering and maybe 3 around SMP North Circuit with the Holinger with oil pressure warning alerts, which ended up being a case of trimming down the alert threshold at low rpms.
Should be fun once its sorted!! Still got to get used to the sequential but no problems slaming through the gears with the foot flat to the floor down the striaght !! :)
Ok guys, I need help finding a rear wing... Voltex can't make me one in time, the local APR distributor has not got back to me, He said he was getting a few dual pane Nemo style ones in (designed by the man!!) and I asked that I get my name put on one...
Anyone have any suggestions on where I can get one quickly or know someone that has one lying around ??
It needs to be 1695mm + 200mm long (including end plates) !!
Michaels email is [email protected]
http://www.kognitiondesign.com
Or lightning composites are in aus http://www.lightningcomposites.com.au/
As are topstage.
Edited by DCIEVE
Thanks... Freddy seems pretty good. See how I go. I like his front diffuser too.
Need to find someone to make the wing mounts. Thinking of going around the back and under the car ala GT3 style??
New fuel system was fired up today.
New Turbo should be delivered by end of next week.
Will need to wait for Jim (Tunehouse) to get back before it gets tuned. Gives me two weeks to get everything else done.
Still need to choose wing, get it and sort out mounting.
Front bar needs to be remounted and secured better as it broke the side mounting bolts and was dragging on the ground at speed.
Ive been away, back tommorrow... Time to pull the finger out!!
Do you want it in dry carbon or fiberglass John?
I have a custom widebody fenders that will clear 315/xx/18 11-12 inch easily. I have a spare fiberglass front fenders, Topstage has the moulds for both front and rear fenders atm. If you are keen then you should talk to Freddy but I think you are leaving it too late.
The rear will involve cutting your whole fender off and replace it with a dry carbon piece. The front is "almost" bolt on. I made some modification to the firewall for aerodynamic reason and the fender is shaped for it...if you struggle for time and dont have time to modify the firewall, then cut off the inner "flare" of the fender and bolt it straight on to your car..it should still help with the aerodynamic.....that's if you sweet talk Freddy into working 24 hours.
Best bet is to flare the rear and look for another wide front fender. I searched everywhere before and could not find a dry carbon one or even a wet carbon with aerodynamic on it for the r32 gtr...hence I had to design my own. I even bought one from EA and it did not fit. I am happy help you out if you are stuck and let you have my fiberglass one, if you need it, with the right offer..... I really don't know how much it worth...but it costed me a bomb and lots of hours.
Check my build thread if you want some pictures.
Talk to Freddy John. Between Freddy and I, we have most of the R32 GTR body moulds. I don't really know how much to charge you for using the mould...just ask Freddy for a fair price....happy to help another SAU member.
Good luck John and it will be good to catch up on the day.
Thanks for the offer on the front guards just pm me what you want for the fibreglass front guards and send me some current pics of what they currently look like... I will let you know if I am interested.
I was hoping for a bolt up straight fit solution to the front guards and Im anticipating the rear is not going to be that straight forward.
Im not looking for a long term solution as the car will be going on a diet after WTAC and Im going to have a proper look at the aero.
My priority is to get the mechanical, electrical and chassis sorted and get some seat time... Everything has to work and be reliable hence the looks are not so important for my first WTAC...
The FG were prepared and primed for the mould. They have been wrapped straight after moulding and in storage since. I won't have time to take it out just to take pictures but it should look like this
These look awesome! How much wider are they, and are these actual pics of the guards to fit R32 GTR?
Do they have more clearance for extra lowered cars as in John's car now has the option to go lower as the roll centres are raised?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
