Like Deca? Wish It Were Closer? Wish No Longer! New Skid Pan In Melbourne!
RTR - 'Road Track Rally' have delivered...... baller style.
Yes, you're seeing correct. A 9000 sqm (i believe) skid pan VERY soon to be available in western Melbourne. Prob 30-45min'ish for those of us on the civilised side of Melbourne :D
Slightly smaller than DECA overall, but i think maybe a little longer... not 100% sure
Not April fools, this is full legit, ready to rock early 2013!!! Bring it!
oooooooooooooohhhhh yeeeaahhhhhhh.........
  • Replies 76
Like DECA?
I see no back track :huh:
As said in the other thread (might have been wasteland), hopefully it doesn't go the way of Drag Tag's skidpan that ended up having the Law sitting out front of it all the time. Although it wasn't built as a skidpan given the main business is Forklifts... So council likely don't know it's going to be used for "that"...
oh yeah, no back track, but 'like DECA' i meant is in the 'affection' variety, not necessarily by it's exact make-up. But still, great to have an autocross venue close by - google tells me 45mins
public events? as long as there is an event you can join, then that's all we need. SAU DECA aren't exactly 'public' events, still need a CAMS/ASAA (or aasa whatever) license. I'm guessing it will be along those lines
i'm sure this is a multi-purpose venue, but will cater for motorsport events.
If anything, this will be a good compliment for DECA, you can do these events close-by but if you want a day mixed with some tight track action, you can go for a DECA.
hahaha, yes Grant, no armco :D
Ye that's cause it's all 100km/h sans the Westgate section :thumbsup:
It's still 25mins from the CBD regardless was my point, as it's being claimed as "10mins", which is just rubbish as it takes 10-15mins to get the the WGB from the CBD - i do it regularly
this isn't a workshop war thread, not that there is one going on, this is just to let you know we all will have a DECA (skid pan) sized facility available to us for autocross events. That's it, we should be all grateful for having motorsport facilities closer to us... isn't that what we've always called for? Yes it isn't another metro track like Sandown, but good luck that happening. And no there isn't a back-track like DECA, but it's still potentially a great facility to have some safe fun, that's pretty easy on the car.
10-20mins whatever, all i know is that more close motorsport venues the better, no?
You must drive slow I regularly do point cook / hoppers crossing to city in 15-20 mins
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
