Yeah you're right Scotty. Double checked my figures today, and the injectors are maxing out. The FPR will get me out of the shit short term but I'll be getting it tuned shortly. You get the email from the HKS guys about the tune?
No mate, no emails about the HKS...
  • Replies 42
So Cihan should disclose all his tuning secrets so other tuners can copy his work? It won't happen... Too much time has been invested by him into the VQ25det now to just give the information away, I think my car has over 200 dyno runs on it already...
Not far to drive over Ryan for peace of mind...
Its not, but it becomes a pain in the arse to go back and forth every time I need a tune. Would rather work with someone local who is good and is interested in spending the time. There are a couple who have expressed interest, one with their own dyno.
It's interesting how this happens; your guy (and you) had to go through the learning process, and now there is more demand; the guys who put it in the "too hard basket" suddenly need a hand.
I don't doubt you have plenty of your own cash tied up in the entire process Scotty; no way 200+ dyno runs is a cheap process.
If your guy is good and interested; that is the ideal combination!
Maybe it would be worthwhile him investing his time and effort, so that he can hold himself up as one of only a small number of tuners that can work on the M35.
If you build it; they will come.
Exactly Dale, and that 200 runs isn't including the Emanage learning process before it.
I do honestly hope there are other tuning options and tuners in the future for the VQ25det, and if the guys at Nistune finally get on board we will all benefit. The HKS software is the best option available to us at the moment but there are so many things I would like to adjust that it doesn't have the maps for...
Agreed. Surely if your tuner is interested and is competent he doesn't need his hands held by someone that's done all the work...
Not for free anyway!
My tuner doesn't Jethro, it's the HKS guys who needed more information. The information they needed I don't think we could get from Scotty's tune anyway, as he's running non standard injectors.
Andrew now has these for sale on his web site: http://amperformance.com.au/product/miscellaneous/nissan-m35-stagea-performance-cold-air-intake-pipe
I will hopefully have a group buy price shortly for all those people who've contacted me.
  • 3 years later...
So after installing, good increase in response and power.
Need less throttle to get the car rolling and coasting on legal speeds.
Car seems to have more rasp in exhaust note and engine feels slightly less smooth in the rev range.
Does this sound normal ?
cheers
Wow what a difference the intake makes on stock tune.
I've put the power duct cover back on and blocked half the stock snorkel to reduce airflow until my tune.
Back to normal, engine smooth, better idle and less noisy.
How's that for home tuning !
Block off the f**king intake...
So is it possible this intake could cause the ECU to change timing ?
It feels like a late spark or something.
Still surprised I have rough idle and engine rev.
Blocking off power duct has helped a little but not much.
Just had another thought.
Maybe air is coming in through the join, which is after the AFM.
There's no physical seal on these,just metal to metal.
Gonna try and get a clamp around it.
A clamp probably won't help; but a solid application of tape around the join will tell you if you're on the right track.
  • 1 month later...
Yep these intakes DO leak between the middle join.
When it's fitted the two halves are pulled out a fair bit stretching the spring.
After doing a smoke test, it was visible.
So had it removed and sealed with silicone.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
