Hey all,
I have a 33 gtr and I'm looking to add some cams.
I'm going for tomei as no extra work is needed just drop in.
But I'm unsure to go type a or type b.
I'm not the most mechanically minded so reading specs isn't helping me.
What would I notice in the way of difference installing one over the other?
Which should I go for?
My set up is a forged rb26
-5s with the bolt ons making 340rwks at 18psi
https://www.sau.com.au/forums/topic/414909-poncam-question/
Does make more power with less boost.
Tough idle.
better midrange and topend.
Check out the RB26 dyno thread. You'll find my graph (tomei type b) and my mate's Sloane, similar cams, and other similar setups.
https://www.sau.com.au/forums/topic/414909-poncam-question/#findComment-6653175
Will it make it any more responsive? More torque? More kws? Etc?
On the street or a dyno?
I know two people who took them out (for stock), went faster around Sandown. You be the judge, it's not just about dyno plots when fully loaded.
I've said that enough over the years so I'll leave it at that.
https://www.sau.com.au/forums/topic/414909-poncam-question/#findComment-6653214
Or keep the stock cams, tune to 22-24psi and see how much it makes then.
If it's 360+ keep the stock cams.....
If you want to push over 390-400 the stockers may need replacing.
In the end it is up to you.
https://www.sau.com.au/forums/topic/414909-poncam-question/#findComment-6653237
Such contradicting info out there over cams! My tuner said i should get them but others say dont bother etc.
The car is a daily driver with drags on the weekend in mind.
Also while people are reading, my boost controller is a AVC-R, ive never had one before. does it allow for a high / low boost settings? ie 17 - 18 psi daily. 21 psi drag day?
https://www.sau.com.au/forums/topic/414909-poncam-question/#findComment-6653613
You can have either high, low or off setting, all this depends on your wastegate spring of course, its a good controller, in your lower gears like second you can increase the duty to fine tune, you can ramp it up early too just be careful if you dont know what your doing...
https://www.sau.com.au/forums/topic/414909-poncam-question/#findComment-6662296
Yup strongly agree with this I found out real quick what over boosting was when first attempting to use the avcr who ever ends up tuning get them to show you
https://www.sau.com.au/forums/topic/414909-poncam-question/#findComment-6663944
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
