Hey guys,
So to keep it short, got bored of the VQ and its slush box, the engine's compression is too high to boost reliably without selling a kidney, and on top of all, the VVEL will forever be a bottle neck on this engine. Solution: RB30 swap :D
Picked up an RB30E bottom end, cast iron block, long stroke, with enough torque to move the G around, mated to an RB26 and an RB25 pull type gearbox since I will be keeping her a RWD.
To this point, we got the following:
RB26 head & RB30 block, waiting on head bolts, gaskets and cam belts
RB25 Pull Type gearbox
A snail crawling around in my living room... (GT35 Compressor mated to a T04 turbine 090 trim)
RB26 Intake Manifold
RB26 Exhaust Manifold
VH45DE 90mm throttle body, mechanical throttle FTW!
Update: 26-11-2012
Gasket kit, head bolts and tensioner kit have arrived and have been dropped off at the shop. Aiming to start stripping down the G on Saturday!
The manifolds were just held against the head to measure clearances from wheel well, we may have to re-route the wastegate pipe.
Intake side should not be a problem
Update 28-11-2012:
The head has been sent for porting, polishing and final prep work before getting fitted back in. The block is getting painted and drilled for the tensioner.
In the meantime, this showed up at work today:
3.5" intercooler and an Oil Catch Can.
Update 03-12-2012:
Engine and head are finally ready! Car has been dropped off today to begin surgery. Here's what all the head covers and pulleys look like so far :D
Update 06-12-2012
Engine test fitting began and it is looking great so far!
The intake manifold inlet will he have to be slightly modified to fit the throttle body due to limited space
The turbo side however is a tight fit
The wastegate pipe is a little too close for comfort too, may have to be modified as well. No so sure yet. It is looking great so far!
Update 08-12-2012:
The following pictures will not be easy for the weak-hearted :P
Doesn't that shifter look like it just belongs there? :)
Well it wasn't work of magic though, the transmission will have to be pushed around 26mm away from the engine to get the shifter position where it belongs. A spacer will be made to sit between the engine and transmission housing. The flywheel will also have to be pushed by that same amount. You can see the tiny spacers currently being tested.
Since the transmission's cross member will be slightly relocated, some new holes had to be made
The crank case also wanted a share of the action, it wouldn't fit properly around the engine's cross member so it had to be modified. The mechanic suggested he will be test fitting an RB25 crank case as it may be easier to work with, let's see how that goes.
Transmission alignment in progress
The wastegate pipe continues to pester around, this time around the steering column. The mechanic says the engine is not 100% aligned yet, once done it will move further away from the steering column.
Stay tuned for updates!!
https://www.sau.com.au/forums/topic/415236-my-v36-rb2630-swap-going-all-in/
Looks good, but I'd this really cheaper than rebuilding the VQ and auto box to handle decent boost?
Much cheaper, a VQ twin turbo kit from GTM is $8000 alone, and that's without shipping to the UAE or labor or supporting mods. An MT transmission swap will upset the OEM ECU. And after all that, I'm still stuck with a high compression engine (11:1) that would be like a ticking time bomb.
And besides, the RB engine is a lot more fun!
What tuning options will you choose?
Looks good man.
Also once finished.. have fun on Jebel Hafeet Mountain Road... :D
I'll be going with a Standalone ECU by Adaptronic.. Jebal Hafeet will get a share of my tires that's for sure!
I hope you have someone good with electrics to wire all that stuff in. :)
So its just a std 26 head bolted on a Std 30 block?
Yup someone real good and an Aussie too! Yup, OEM 26 head that's been machined and brought back to OEM condition
  • 1 month later...
She still doesn't sound 100% right. I discovered there was no IAT sensor hooked up which is probably why the ignition timing is all over the place. Will secure that and see how the engine responds. Until then.. enjoy :)
  • 2 months later...
Just a quick update, Engine was rebuilt with CP Pistons & Manley Rods, Nitto Oil Pump and ACL Bearings. Figured I'd do it right while the engine was opened up anyways.
Here's what she was like on 12 psi
Edited by G37Sam
Needs more boost. So I'm guessing the stock motor was stuffed, hence that terrible sound in the first vid?
You running in the motor? How much power you expecting once you turn it up? Hope youll be getting a decent turbo on it, cause current one looks china special.
Yeah the engine took a dump on the dyno, when we took it apart we found out the bearings were shot. So I figured it was time to rebuild it. The car is now running at 17psi WG pressure and 21 psi with boost controller. Still room for more but it's getting too bloody hot here so I'm keeping it safe :)
The Turbo came off a 2JZ that made more than 500whp btw. It's not the best turbo in town I agree but I got it for dirt cheap just to use as a starting point. It will be replaced with a nice 6266 along with some poncams as soon as the weather starts cooling down again ;)
I don't see why you would convert to RB30?
Rebuilding the bottom end in the RB30 would be similar cost to the VQ37, also change the compression ratio while you rebuild.
$8000 for the turbo kit is not pocket money, agreed. But remember that is all brand new parts and a full kit, probably including wastegates etc
You say that a MT swap would upset the OEM ECU, but you are replacing with aftermarket ECU anyway?
No doubt that the 26/30 engine is capable, powerful with great aftermarket support, but I feel like the VQ37 would have done just as well, if not better.
Have you noticed any change in the vehicle handling? With the new engine I imagine being a lot heavier (iron block) and more weight further foward (I6 versus V6)
An aftermarket ECU is near impossible to run with the VHR head (VVEL controller). People are only tuning and are limited to an UpRev flash. Converting to an HR head is a whole different project.
It actually handles better now because I fit in some coilovers :)
The RE5 auto is a little weak for the task, but mine is going ok now it's built. A box is quite easy to transplant as you found though.
The VQ's are very misunderstood, your engine was more advanced than the VR38. You missed a golden opportunity, uprev or not. The Link G4 extreme would have run it with some Guilt toy input...
Trust me, I've driven the VQ37VHR for five years and spent a lot of time on myG37 forums. It's a great engine to run naturally aspirated. I just wanted raw power & torque with an M/T gearbox and non restricted tuning capabilities.
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
