I'm after an **R34 GTT Drivers seat** if it's cheap enough.
The drivers side bolster on mine is falling apart :(
Can have it repaired but if there's a good one for not much then it's the easier option :)
yeah yeah yeah - enuff batfastard jokes
Mitcho_7, on 06 Feb 2013 - 22:12, said:
I have a random 17x8 inch rim, it's an advan rim.
I got three advan rims with my car (i assume the other was busted) so youre welcome to take the odd one out for a small fee.
and done...
Thanks heaps Mitcho, Nice to meet you. :thumbsup:
