thanks for the update muz....joe was talkin bout movin back to mobil when i was down there a few weeks ago but hadnt finalised anything with charlie yet (owner/mechanic at garren) and its great to see him becomin quite well known to the import crowd. as you can see i have nothin for praise for Joe and no one will be dissappointed with the service he give his clients, he just goes out of his way to get the job done right and fairly....wish i could find a mechanic here in bris that was like him
jeremy
mercury motorsports are good in brissy. but try to avoide TRACKSIDE PERFORMANCE they did a simple service on my last car and put the wrong plugs in and didnt put oil back in my car after draining it. also they f**k the oil pressure sensor on my dads car(which then leaked the hole cars oil out) and said " yeah mate we'll fix it and only charge you parts. there a bunch of D grad wanks.
anyway, mercury motorsports. there good (07) 3352 3363 sorry to hijack the thread.
(ow and im moving to greenway ACT, on friday so ill see you guys at the ignition thang and the photo cruise ;)
Aif
  • 3 weeks later...
  • 3 weeks later...
Can anyone tell me a good place who can replace my suspension bushes? My rear control arm bushes are well shagged (can wiggle the wheels in and out when it's on a jack/hoist) Wanting to get the bushes replaced so i can get them out of the way and move on to coilovers after that for a nicer ride and so my car doesnt look like an r33 trying to be a Subaru outback:D
a number of places in canberra can source & replace your bushes, but to save money i'd recommend sourcing them yourself. i got mine through auto one in phillip, make sure you speak to Tai.
driftshop sell front & rear end adjustable suspension component packages at good prices for a heap of cars, including R33
once you've got them, see Chris at Inline suspension on Yass Rd in Qbn or Craig Hall Mechanical in Phillip
    • So my rb is finally having more problems. 2 issues here but I'm here to just to mainly discuss the rattle noise. The other day when I turned on the car and when I take off or go in reverse, there is a temporary rattle noise but when I cruise, boost, idle it's completely fine no rattle whatsoever. I've also done all the servicing, all the health checks you can think of and it all passes with flying colours.  Also the rattle doesn't increase with rpm, it's only at a very certain rpm (slightly above 1,100rpm). My other car also has the same issue every once in a while. Changed the oil recently, no difference. Even took my oil to a lab and everything was quite good surprisingly. Timing belt changed a while ago to. Had the car on the hoist and can't see anything obvious. Tightened a couple of nuts on the exhaust manifold a couple of months ago. 2 different clips uploaded. One of them was supposed to another issue but I'll save that for another time. Thought I'd see if anyone had this same noise before, it's a bit hard to diagnose while it's intermittent. If I'm not mistaken, I think I had this a while back but can't remember exactly. I was thinking if it's doable I'll get someone to hold the throttle cable at 1,100rpm and hopefully it replicates the sound. rb25det rattle only.mp4 rb25det slow start + rattle.mp4
    • Haha wow, yes they do! Will sort tomorrow.
    • Yeah I’ll know when I take it for a test drive and I’ll double check the turbos as well when I have a look at it again.  Just thought maybe they might have done something in the head cause it looks like they’ve taken off the rocker covers 🤔 Thanks for your info!
    • As Duncan mentioned it's likely a remapped ECU, like the the one listed in the link I post earlier:  https://minkara.carview.co.jp/userid/444260/car/444612/2099320/parts.aspx He quoted 444PS with an unopened engine and twin GT2510s @ 1.1bar boost... sounds about right?
