reviving an old topic :action-smiley-069:
decided to give the plastidip thingy a go today, did my front grille and rear diffuser. The grille turned out okay..got a few small run spots if you look close but from far it looks good imo. I did 4 layers on each with 1 can which was almost empty when i finished. The diffuser didn't turn out as good as i wanted it to be but being first time i think it was okay...will learn from my mistakes i guess. Anyway pictures say more than words, here's a few pics i took along the process (only took a few as i was racing against daylight to get it finished.
Grille (was a bitch to take off lol..)
after
Diffuser
i was bit paranoid about overspray...hence the ridiculous amount of paper lol
after....i ran out of sunlight :down:
dd94bc92-8da8-4ac4-98e1-c0a8075156dd-1.j
took me about 2 hours ish, that was including washing the car and prep work :happy:
after
Diffuser
Looks good.. :) Why do you think diffuser didnt come out good? I was thinking of doing the same so any tips would be handy.
Cheers
When you peel off the masking around the edges the dip tends to stick and wants to come off with it. I was being pretty careful but still left a few tiny spots on the edges. After some reading I found out you can either spray the coats on fairly quickly, don't allow it to dry and peel off the masking while its still wet, that way you get a smooth clean edge. Or, you can use a razor blade and cut alone the edges where it bonds to the tape and take it off that way, hope this helps. =)
Thanks mate, I ll see how I go.. :)
Chucked all that stuff on and removed the bottom resonater from the air box too.
Surprised at how much induction noise for a stock setup now :)
How do you take out the bottom resonater from the air box? Does it just come out or did you have to cut it off?
By the way are you referring to the part in this photo or is it at the bottom of the air box?
Thanks Locky.
Cleaned the throttle bodies of my 370GT this weekend, as I was experiencing idling issues (sometimes the car would stall...)
Bit of a pain to do if you can't remove your strutbar, but it makes a world of difference.
Mine was covered in black grime, and now its nice and golden..
mods i have done from then to now
Coilovers
19x11+15 varrstoen 1.1.2 (please don't hate on wheel caps came with the wheels :P)
JDM Double din stereo kit
Custom Y Pipe back exhuast system
Roof Spoiler
Hey Sarl,
Where did you get the varrstoen from? and what coilovers do you have? Did you have to roll your guards/ fenders with the setup?
Thanks
Hey Sarl,
Thanks
i traded my old wheels for them on gumtree, but ebay has a varrstoen seller which seems legit.
had some basic coilover i found on this page but might upgraded later on to bc's
all i needed to do was rolled the guards and had to shave a bit or my rear bumper lip inside and also camber
hope that helped rawzz
Bought a Greddy emanage ultimate with boost sensor, loom and laptop with software for the VQ25DET swap in my sedan.
Also bought a rare-ish woodgrain MOMO optioned steering wheel.
Did UpRev tune yesterday. Not too bad I think :)
Nice, workshop and details?
Pity the run rate is different on the runs. The curves aren't really comparable. How does it drive?
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
