Installed a catco high flow cat I bought from Pattey a while ago. Nice to hear some gurgling when decelerating haha. Can't feel any difference from stock cat but hopefully its made some difference :/
glad it went in okay, without a back to back dyno/run of road and accelearing style will be difficult to tell the difference of just a high flow cat.
Yeah I thought that would be the case. Getting a tune in a week though I'll have nothing to compare it to coz no data prior to the high flow cat anyway.
Re-did my center console gauges because my water gauge carked it. Spent a little more this time, but definitely no defi quality. Quality seems a lot better then the last gauges though..
Gauges look good Chris. Cheapy ones don't last well do they? My cheapies died too.
Was considering Saas but they all seemed to be in Bar and F0 not PSI and C0 .
Happy with my Specos. :)
Are you still suffering Boost issues / R&R etc? Surely you would notice better Midrange / Top end with the New Cat.
Happy with my Catco. :)
Yeah I found a psi one online.
Hard to tell if i have a boost issues. Car isn't 100% at the moment. Needs a tune. Still pulls hard but it's a bit laggy. If I had an air compressor I could make a boost leak checking thing.
Yeah I figured even if I don't feel it at least I have peace of mind that the stock cat isn't in there causing a restriction.
Stuff was done...... :ninja:
Sure was! The Green Machine Lives! :woot:
Today I finally removed the 2 Big Blow Flies from between the windscreen and dash in the Wagz. :laugh:
Also put in the New Floor Board I cut at work which got a little Grey Paint brushed on for definition.
(not sure whether to put it under the carpet or not.)
Pulled out the Panhard rod and convinced the old Bushes to GTFO and make way for the new ones.
post-78856-0-28847200-1400318049_thumb.jpg post-78856-0-13299300-1400318051_thumb.jpg
Not much in this pic hasn't had some lovin' since I got SkyWagon.
Yeah it is a little bright but Classic White is the main colour we use at work.
I've done a raw MDF one aswell, minus the logo.
Was your IACV not fixable with a good clean?
What did rob do to his car today?
Rob is the master of motivation. :worship:
Now the paint is on, im back in the game......... :banana:
I got a big box of goodies saved up to fit during curing time.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
