Cleaned up and put the stock rims and hubcaps back on the Micra and added a little more air.
Retightened the front wheel bearings and a few hose clamps on the Wagz.
yesterday/today:
Re did all the vacuum lines with new Aeroflow lines. Cleaned and waxed parts of it. Polished my key, and ordered more OEM parts.
Also did a complete clean of the interior including the seats. Smells good :yes:
Washed the Micra for the last time and arranged insurance for the Pulsar.
Exchange will happen Tomorrow.
Exciting.
Congrats mate, look forward to hearing about what 'tweaking' / 'tuning' that can be achieved with a late model Pulsar ....
What did I do to my car today!! I got it freakin filthy dirty in the rain after washing it on the weekend!!
None of those mods are likely to void warranty so they may well happen :D
The phrase "it's Ridiculous" has been said alot this evening.
It's so much bigger than previous Pulsars and actually makes the 33 look small. The Pulsar is only about 100mm shorter. :O
I'm going to have to totally rearrange the garage to suit.
Despite being able to put a clenched fist between the tyre and guard, the front bumper is closer to the ground than the 31s after being lowered.
The boot is the biggest I've seen and yes I climbed in. Easily enough space for 2 of me, maybe 4 if stacked.
The dash looks awesome at night, the headlight height is adjustable at the flick of a switch, the 1.8L gets it moving just fine, Auto box is smooth as silk,
as is the general ride comfort. It's soooo quiet and comfy. Very easy to drive.
Really Quite Amazing. Can only imagine what an R35 is like.
Makes the 33 and especially the 31 feel Really Old.
Ridiculous I tells ya.
  • Like 3
Rewired fuel pump, put another big cable between alternator and battery to bring fuel pump voltage up from 10v to 13.8.
Hoping to run it out of fuel on the dyno again but to make more that 430hp this time!
Also my drag radials are waiting for me at the Toll depot :)
In the next few weeks I need to source GTR rear suspension, get diff gears and pinion flanges swapped, fit GTR cradle, modify handbrake to suit, fit BM50 master cylinder, wire up overdrive on the auto (and maybe also lock up converter), get a wheel alignment and figure out how to fit 200L of eflex in the car to get me to Coota and back. I think I can do it!
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
