Installed 24mm sway bars with the help of Dontyellchris and Sinister Industries last night. Thanks Fellas for the top night!
Great night! Thanks for hosting, couldn't turn down the offer of free beers :P
How'd you go with the strut brace? Fouling?
  • Like 1
Was a great night even managed to polish my headlights and fall I love with the project again
  • Like 1
Haven't tried yet Chris. Ran out of time yesterday and it is in getting an alignment and semi's put on the GTR rims today. I'll have a crack tonight.
  • Like 2
I need some opinions about this hicas eliminator kit, has anyone used it before? I am planning to put it on my r34 gtt
http://www.ebay.com.au/itm/161631311362?redirect=mobile
Just wanted to see if anyone here has bought/used them? [emoji120]
  • 4 weeks later...
No, had an Autronic SM4.
Not a bad ECU but was about to hit limitations and while it could be made to do a lot of extra stuff was always a lot of extra effort to do it.
I'd have liked to go the Motec but can't justify the cost right now and I want the flex fuel. I am doing the Motec dash though, sensors galore!
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
