You CUT
I sat and looked at her bleed green on the garage floor today. Drip.........Drip............Drip.
There was nothing I could do, :/
James have you been round with the cutter ??
i cut cut
i bought myseft some bolt-on's, miranda wouldnt let me put them on her..
Looks good.
I didnt do anything because i decided to play hide and seek with my keys and spare keys. FUUUUUUUUUUUUUUUUUUUUU!!!!!!!!!!!!!!!!!
While your looking, I lost a set Honda keys last week. If you find them I'd appreciate their return - ta.
I think for guys it's called an extension, not a bolton.
But they look really good James.
Found them!!!!!
Looked in the same place so many times and they still magically appeared there when someone else looked :/
I made a template for my new airbox and started tidying up the engine bay! Will post a pic later
Found them!!!!!
Funny. I am thinking of making an air box soon too.
Should be titled what Sinister did ti my car today.
He brought my wing back to almost new and some other scuff marks on the paint with some buffing magic.
Also gave me a late Chrissy present.....Get your minds out of the gutter! LOL
Thanks Richard, your a legend mate. Much appreciated.
Finally got my ass of the couch and lowered my car so it doesnt look like a 4x4 lol. I think the lowest point is about 98mm so its pretty close to legal :)
Also cleaned up a few little bits and pieces in the engine bay. I removed the bracket that the injector resister pack attaches to and just mounted it to the chassis. Also relocated my FPR to the strut tower to neaten it up a little. Pretty dodgey pic but i couldnt find a camera lol. Still unsure of what im going to do with the hks grounding kit thats on it as it looks really messy (not that you can see it in this pic).
Edited by k_d
Drove the Micra to the coast on Monday, such a fun little car to drive.
Had to drive the Arse out of it to get back up the hill, so much fun with the dog sliding from door to door on the back seat.
Used 1/4 of a 41L tank from Dalmeny to here with aircon on alot. (not on hills).
I swear 70 of it's 79kw go on the aircon, flick it off and it's like hitting boost. LOL 1psi boost maybe???
Got home & started the Liner up for about a minute just so I could hear some engine. :D
Edited by Not a Pulsar
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
