  • Replies 43
Posted Images
i would buy yours in a heart beat for 12k!!! :) That's about the limit of my budget though :( If you are desperate to sell let me know and I won't even bother test driving any, the money will be in your account within 20mins haha
Not in any rush, for $12k I'd rather write it off into a pole. I sold my father in laws 1999 Hiace for $13k.
lol no doubt - I was not trying to annoy you by putting a stupid offer in, just wishing I had 19k to spend :)
That first gold AR-X looks good. I'm guessing the first owner in Japan must've ticked almost every option box. The only factory options I don't see are dual climate control and rear hatch spoiler. It even has the safety pack. All M35s have dual front airbags but only a few have curtain and side airbags and rear seat centre lap-sash seat belt. It looks to have the Bose stereo, HICAS (4 wheel steer - love it or hate it), auto tilt/fold mirrors and reverse camera. Someone has even installed reverse sensors. Going by the rear fog light, I'd say it has the cold pack which also includes heated mirrors and windscreen. But you would also need to check for underbody corrosion (salted roads in the snow). The tan colour if I recall correctly (it has been a while since I sat in one) is the darker of the pictures almost like a Crunchie (honeycomb). I haven't seen that rear number plate trim before - looks OK but would probably look better colour coded.
As Ryan says, the white M35 is not an AR-X, but it does appear to have the rare safety pack as well.
IMO on face value, the gold AR-X looks to be better value of the two, but I would check out a lot more M35s before settling on one.
Cheers
is the autech axis quicker than the ARX?
I am still trying to figure out all these different models from the different years etc!! hahaha it's not a lack of information but drowning a sea of numbers and dick measuring contests that forums seem to fill up with!! :) hahaha it's all good though I am figuring it slowly...
They run a GT-R engine and the AWD system from the 33. I know the owner of that stagea and that thing can keep up with my GT-R.
http://www.skylinesaustralia.com/forums/topic/413070-1998-nissan-stagea-rs260-autech/page__p__6609844#entry6609844
He's talking about the C34 RS260. The earlier model Stagea. Made by Autech.
There is no mechanical differences in the M35 models made by Autech (other than maybe springs...)
caveat being the 350S which we can't get...
this^^
OK that makes sense... my wife is pressuring me to get a car with more comfort options, so I think I will be stuck with the M35 models, one that has leather etc etc etc... That RS260 does look pretty sweet though!!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
