Was it the earth strap in the engine bay ?
I think the attessa system has more earths under the back of the car in the boot?
Glad it's sorted mate go hard !!
yeah. The earth that holds the car battery as well as an other earthing wire.
It goes alright lol
  • 2 months later...
Rightyo its been a while since I did anything with this thread
Heres a few pics of the car at Lakeside Raceway back in October
lol @ that wrxy handycam
#DATE85LYF
Cars cooling off after the session
c91024f0-d6f5-4095-b1c0-d2363a83740f_zps
the brakes were fecking hot - need to fabricate some brake cooling / air ducting next also that brake dust is nasty, predominantly because I think my rotors are not facing correctly :dry:
cleaned her up once I got home
enjoyed a well deserved beer :cheers:
  • Like 3
Been experiencing voltage drop at idle after driving the car and think it could be the battery
Over the years I have been going through wayyyyyyyyyyyyyyy tooooo many batteries
And after some research I am thinking my alternator is one its way out.
So I procured this
RH9 Alternator 130amps - hope this fixes the voltage drop issue (fyi it drops from 13.5 to 12.8 or lower at idle)
Came with this sticker - so cool - not that am worthy of putting that sticker on lol
  • Like 2
Nice shots antsy pants
thanks dude
Nice work. Was that a general fun day @Lakeside?
btw looks like one of those rear pods is sticking out a bit?
Yep, was SAU QLD happy laps at Lakeside has to be my favorite track
Yeah, I have since fixed that rear pod but may have to sikaflex it
So I procured this
and not only do they work really well they look blingy too :thumbsup:
Edited by Sinista32
Next issue.
Miss firing whoes.
I had my plugs fouled at the drag day so I thought I would replace them.
I took the coil packs out and they looked like this
f35c70b0-9c7b-4098-bd59-b57bde4d670a_zps
they needed some serious TLC
While I was at it thought it would be good to source a new coil pack harness as the other one looked rather brittle and stiff
also got some brand new NGK platinum spark plugs BCPR7ES and I gapped them to 0.7mm
baf8d6e2-79ef-444c-a3b4-11b28ebcd86d_zps
I cleaned up them coil packs and also go hold of some dielectric compound and applied it to the coil packs where required and also around the spark plugs
Plugs, coil packs and new coil pack harness all reinstalled
Went for a drive and car felt more responsive but more importantly goodbye missfire, happy Frenchmen I was
  • Like 3
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
