Thanks Rudi,
And to you to and your family.
Extending my well wishes, and remember to drive safe if your travelling over the festive season. Remember to lock up the place and secure valuables - Crims love the holidays.
https://www.sau.com.au/forums/topic/416118-merry-xmas/#findComment-6679607
Merry Christmas guys, great meeting more and more of you; a great community to be part of.
Stay safe.
^^^ THIS!
Met some great people, and everyone always seems to be willing to help out. Thanks to all!
Merry Christmas and have a great new year!
https://www.sau.com.au/forums/topic/416118-merry-xmas/#findComment-6680144
