There is a law against just staying in the right hand land.
Common courtesy would be to move over to the left hand lane, cept OP decided to stay in the right hand land and antagonise the driver behind him
There wouldnt be a situtation if OP just moved over to the left hand lane as you are supposed to and required by law
yeah, keep left unless overtaking (i am a huge stickler for this rule too) which he was doing. way i see it he was overtaking at the speed limit (assuming the truck was doing 100km) guy came up speeding from behind, didnt like the fact he was taking too long, got impatient and then proceeded to road rage by tailgating and then jamming on the brakes when he got in front.
speeding is against the law, same with tailgating. and i know which of these three rules is the least dangerous to the other motorists.
  • Replies 89
I wasn't going to have it so I slowed down to 100kms to match the truck's speed, and he really hated it.
slowing down to 60kms in the right hand lane of the Hume is the best idea this guy had.
See the parallels?
You're your own worst enemy. Drivers are self righteous tools - how often do you see someone admitting wrongdoing or apologizing for their behaviour on the road? You weren't going to teach this guy a lesson he would learn and you know it, you just wanted to get revenge for him for sitting up your ass. Whatever you did, he was always going to continue on his way driving like a dick. Possibly even worse after being aggravated by another driver. So move over and have no part in his douchebaggery, then you get to live life without him bothering you for another second. You were both breaking the law in your own ways.
On roads that don't have overtaking lanes, I've had drivers sit up my ass before...I sit on the speed limit and they can do whatever they want. I don't slow down, I don't speed up. If they want to sit close enough that they don't have time to brake fast enough, that's their problem...which is why the law, 99% of the time, puts the car behind at fault in an accident. I'm not in control of his car, I'd rather focus on what's in front.
Lets face it though, who hasn't had people fly up behind them on the highway and tail gate them until they move? Doesn't mean you need to inflame the situation and I think that's what Artz was pointing out.
Scares me how many people actually backed OP and said they'd do the same thing.
Someone tailgates me on the highway I might get annoyed but certainly don't deliberately slow down to box cars in.
I get what your saying. But just speed up a little and move over to the left when you can, not slow down level with the truck to not let him pass
douchebaggery. <<<------------------- Word of the day. :)
I sit on the speed limit and they can do whatever they want. I don't slow down, I don't speed up. If they want to sit close enough that they have no time to brake fast enough, that's their problem...
+1 to this^^^ Fargem !
this guy, he gets it :thumbsup:
They both acted like knobs but OP fails for coming here to brag/bitch about it and in doing so potentially flaming out a fellow member/enthusiast...
Its just bad form..
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
