Thanks for the bump,
I have made a few mistakes, no space means Normal GTR.
It does have a rear wiper and Definitely has fogs in the lights but.
Hey gtr judd
I have found this for you mate.
I have no idea what it means but may point you in the right direction
So been busy on the gtr over last few days.
Most of my parts have arrived from japan, last part should be here this week so I can get the car back together! Getting very anxious as I have only driven the car twice since I purchased it. Need to put the turbos back on, new dumps, hks intake kit etc.. so will be very busy this weekend!
Pulled the front bar off other last week as i wanted to repaint my bottom lip.. Matched the colour up at work with a flattening base! came out nice. I also noticed It had a nismo front reo bar.
Unsure why it has a standard front bar, but more than likely had small impact in its time. So I figured the car should get the nismo ducts.
I had a go fitting the first duct last night, came out alright.. took a bit of time using a razor blade haha, but taking my time.
There genuine ones with clips, but need to be painted. Also bought the nismo bootlip too as i'm guessing my car would have had that when it took delivery to its first customer as the bonnet lip is genuine and same as the side skirts.
I have also matched up the original wheel colour the best i could by using the inside wheel with whats left of the original silver. So spent most of monday rubbing them back! Almost finshed preping them and then I can paint them up sometime this week.
Photo is a little crap, but gives an idea
  • Like 1
Looks good dude!
How can I tell if my front reo is correct for my ducted bar without taking the bar off?
I finished putting my other duct in just before and fitted the bar up.. well test fit. Ive got a genuine nissan sticker with the part number still on the reo, I'll put it up when im back home. Will need to take the front bar off to see if yours genuine or not unfortunately.
Finally got the car up and running last night! so much relief and much better to drive!
Painted up the wheels back to original, fitted new dump pipes, nismo bootlip, genuine nismo ducts fitted, painted front bar and painted bottom lip to look original, rebuilt turbo's to N1's, Hks sucktion kit fitted, hks oil filter with greddy oil relocation kit and fresh motul oil!
here are some pictures!
1526454_10152379411508984_65623047572626
10169266_10152379410868984_690299795476710299546_10152379411503984_2454301966153
10313838_10152379410033984_3962681170376
10325374_10152379409273984_6590320158804
10297748_10152379407268984_3338656361956
10268580_10152379407333984_6387521325855
10294321_10152379407278984_6053832170206
bro nice car.
But the glare doesn't give it the respect it deserves :cool:
  • Like 1
Thanks guys! I have no talent what so ever with camera's! What I see in real life looks awesome, but the picture tells another story! hahaha
Might get someone to take some better photos!
Looks great......... Appears as though we are on the same path refurbishing our cars to the next level.
Shame we aren't closer geographically.
BTW...... Do you intend to fit the Skyline and GT badges on the bonnet and guards?
My car is currently at my trimmers fixing the drivers side bolster and redying the front and rear seats.
I'll post up some before and after pics on the weekend.
Cheers,
Bob.
  • Like 1
I kinda like the black outter edge of the wheel cap, I know factory form is silver... easy fix as I have some paint left over If I decide to do them :)
Yeah I would like to do the rest of the badging that it's missing and remove the indicators from the gards aswell. At the same time I do plan to get the rest of the car resprayed at the end of the year or early next, as ive noticed a few imperfections on some of the gards and the typical electrolysis bubbles on the aluminium (which is no drama, just lucky I dont have any rust any where!)
There is 3 colour variants for paint code KL0 and just so you's know it's the number 1 variant which matches the 93 model skylines.
Would you guys know the part number of the badges if possible? and probably re-do the rear gtr badge and Vspec sticker too.
It would be nice to catch up with a few like minded fellows, But I'm out in the sticks lol
vspec II sticker part numbers:
84815MJ 84896-05U61 EMBLEM,TRUNK LID 1994/02 -*2K.GT-R.17 Vスペツク2
side front bagdes
62801 63896-05U00 EMBLEM,SIDE FRONT 1991/08 -2K.RB26DETT GT レツド
GTR boot lid badge (KL0 color)
84815MF 84896-05U11 EMBLEM,TRUNK LID 1991/08 - KL0 2K.RB26DETT GTR
  • Like 1
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
