I think more threads like the dry sump one would be beneficial to create conversation and information.
Threads would have to be specifically Motorsport orientated.
Kinda like the Bruce ducting thread and the cooling thread that are going at the moment in other sections
  • Replies 56
well i was hoping to be apart of this new subforum but the car i was looking at buying was sold before i could look at it. :(
does anyone know of a clean caged r32 or r33 gtr rolling shell sitting around doing nothing?
there are always cheap shells rolling around...I'd talk to Brad or Fatz in the first instance, they both keep their ears close to the ground. An excellent 33 gtr roller with lots of good stuff was just sold cheap....but that doesn't really help you.
Ben, if it's just a case of editting the title etc I can do that, pm me the details, otherwise the easiest will be for you to copy into a new thread and make the changes
I have a 32R at work at the moment which is being parted out and the owner does want to sell the shell.
It's a touch rough around the edges and has a 4130 drag type cage in it. Could be cut out and Redone easily enough.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
