Really? Pm where from was looking at them before however they were either expensive or had a long wait on them.
I have done the same recently too, but i dont know what im doing with it yet.
Nengun. :)
But there is a 2 week lead time on top of delivery time.
I still don't know what I'm doing...
niiice, with all sensors n sheet?
Yup!
nengun looks the cheapest Nick
http://www.nengun.com/greddy/multi-d-a-gauges
That.
Who on here is good with setting up boost on Greddy Profec B Spec II's. I have been trying but ended up confusing the f**k out of myself and turned it off.
Anyone that currently has one running? Also if you could supply me with the settings that would be awesome
Ive got a brand new one for sale Krish but unfortunately I never got around to installing it so can't help bud.
It's a popular unit so there should be plenty of peeps that have used them.
Pretty sure the operating manual is avail online too bud.
Yeah its an awesome unit. I have used it for years and it always works well but in the past they have been tuned when I was getting the car tuned. Now it just has a stock turbo so have to re tune it to bring the boot level down a bit. I found a few tips and hints so will try that on the weekend.
woah def not worth that much for a kit car.
Expert opinion? Once you start ticking the options on those RCR kits, they get pretty f**king expensive. Add on drivetrain, shipping, local engineering..
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
