Hey everyone,
Changed my oil on my r32 gtr, filled it up with 4.6L as recommened, checked the dipstick level and it read only half full?
Decided to run the oil in, came back and the level was just making the 'low level" on the dip stick!?
Left the car to sit and settle for a couple of hours, again, the same reading?
Obviously there's oil lol, the gtr runs fine underload/ boost and there's no signs of oil leaks, loss of power or anything disturbing
I just can't understand why the dipstick gives me such a low oil reading?
Has anyone else had this issue with an rb26 motor? is it a sign of something worst? or is it something rather simple?
thanks
meta
yeah, i should of put that in the post earlier lol, I've poured in about a litre more, however, it's still not going past half-way, so i'm a little frustrated as you can imagine lol
correct dipstick? lol, i'm assuming so, however, is there a way to check if i have the right one for an rb26?
dont assume, know anyone else who has a 26?
did you tip the oil in then check it straight away? cause you have to give the oil al ittle bit of time to drain down. from empty of the dipstick to full should be about 1L
and when you initially filled the oil, if you didn't run the engine before checking the level then it would be lower once you have run it and filled the oil filter with oil. as long as the car doesn't continue to lose oil then there isn't that much to worry about.
thanks for the advice guys, but i have tried for the obvious, the car still reads the same now that it is cold, which is low
Initially it read half, and then reduced down to very low on the dipstick, I then refilled an extra litre, after running it in, so it should be reading higher now with 5.6L, however, it doesn't.
the car sits on a level ground, there is no incline.
Oil pressure readings from the oil gauge in the car read fine and are normal.
It seems odd that the rb26 wouldn't register 5.6L of oil on a dipstick higher than low?
Again, there's no mechanical issues, loss of power or any obvious reasons why it'd be running through this much oil
Does it have an oil cooler?
The initial problem (if you changed the filter as well) would have been the filter filled with oil and this lowered the oil level a bit.
If it has no leaks and you think that to much oil has been put in then it has to be going.somewhere. its not spewing out the breathers or anything?
Also check to make sure your dip stick tube is in all the way and secure....
i had a problem about a month ago where i was checking the oil and it read low ( i was thinking WTF!! the engine is burning oil :S) after checking it for a second time the tube came out with the dipstick wich meant the tube wasnt in all the way..
i re-installed the tube and then it fine
In a different post you said you have a built motor.
Do you have a sump extension?
If you dont have any leaks and you dont have anything taking up the oil, then there must be something you are missing.
If it is a "built" motor I would be checking the sump for sump extensions as this is one of the first things that are done to RB26's to improve oil management.
If it reads low dont go and drive it to see if its gonna read different. Top it up so it reads full before driving
This
Better off being over-full if the dipstick is wrong then under-full if the dipstick is right
i had a simlar issue with my rb25 i did a change and a few days later i started it up and sounded funny so i chack everything and dip stick was almost empy, no spills or anything is shed and i emptied about 5lt in there, so i went and got another and put in approx 3lt it then it was just over full -
then i had it on the dyno almost blow the sump out - emptied 3 lt out to get it down now is fine.. never happend since or before
i couldnt belive it i thought something wrong couldnt work out why it was empty but never was - your not the only one this has happend to.
i checked oil level a few time and was always low before i over filled it, to this day i havnt worked out what the problem was
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
