They sell springs separate to coilovers because before the sudden influx of cheap Chinese/Taiwanese coilovers, such things were the province of race and rally cars, were expensive, rebuildable, completely adjustable and so could be set up any which way you liked. For a price.
^^ Agree. Buying springs individually is for people with quality shocks, DIY, and those with a good adjustment (separate bound/rebound). Also people might go a have a 7kg and have a 6 and a 8kg sitting on the shelf to tweak the rates for different tracks, front/rear bias, etc.
As mentioned, I wouldn't go higher than 6/4 for street. At the moment in my GT-R I'm running old TEINs (no damper adjustment), which I estimate are around the 7-8kg/mm mark. Very good for corners, but for Sydney roads they are way too stiff.
My Ohlins with Eibach springs on the other hand, I estimate them to be around 4-5kg/mm, a lot more comfortable but still decent for handing, has body roll though (softer compression on the Ohlins compared to the TEINS). Nismo S-Tune spring rates apparently are 5.3/4.8 for the R33 GTS-t.
If in doubt, get these: http://www.otomoto.com.au/p/8475209/hsd-ad-type-coliovers-for-skyline-ecr33.html, 7/5 kg/mm with damper adjust. Good for full weight Skyline that you will track occasionally IMO.
A lot depends on how much harshness you can tolerate. I'm seriously considering going back to my Ohlin/Eibach suspension as the TEINs are just too harsh for Sydney roads (35 series tyres don't help either :P).
A mate of mine got the Blitz set from Just Jap for his S14. They are 8/6 but more comfortable than my TEINs. S14s are obviously lighter as well. Food for thought.
  • 1 month later...
Im in need of some expertise with my set up, currently have http://www.nengun.com/cusco/zero-2-suspension With what im told are aftermarket springs of what he thinks are 16/18 or something stupid...
There is no one really replying in the "what is my spring rate thread" so what are the options with changing signs, Just get the right diameter to fit an prick the rates i want?
gawddamn sorry always get them mixed up
so while i'm here, can i get some mine's eibach springs from a GTR set of shocks, and stick them on a set of Bilsteins for my GTT?
And where does everyone buy their springs? I only know Pedders n King Springs here in Sydney. Does the diameter have to be exact in mm to sit on the coilover, its pretty hard to measure it with the spring in-car
Yes the diameter has to be right. But, they're supposed to be all the same. Something like 60mm internal diameter, or whatever it is supposed to be.
The places to talk to about springs for coilovers are the DECENT suspension shops (which counts out Pedders). There are examples everywhere. Places like Drummond, MCA, etc, that suspension setups for race cars and so on.
Look up K-MAC in Rockdale
Thanks guys, got verniers today n worked out my spring rates from web calculators at 10.7/9 or 11/9- way too hard. Even going down to 9/7 will still be hard I reckon.
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
