  • Replies 120
Yeah I had imagined that they would be happy to do it, however a few people have pmd me and said they would prefer ESP (for what reason i dont know/care, its nothing to do with me and none of my business!). Im not fussed personally but i think there would be more people turning up if it was at esp. If someone is unhappy with this they are more than welcome to dicuss their own dyno day/time with whoever they want, however the one that Kat and myself are organizing will be held at ESP and i will confirm a date on saturday.
Sorry if am coming across as a dickhead, i just want people to understand that we are trying to keep the majority happy and getting as many people as possible to turn up.
If your at ultimate tunes tomorrow arvo ill be there (its between where i work and park so i dont have a choice lol!), feel free to discuss it with me then
https://www.sau.com.au/forums/topic/417227-dyno-day/page/3/#findComment-6700979
Agree with you.
Happy for Shell to have my posts deleted re ECu to clean thread up.
I think this thread is already too far gone and can be left as it is for the sorting out/planning...... when a definite date and location is locked in, another thread can be started calling for entrants.
https://www.sau.com.au/forums/topic/417227-dyno-day/page/3/#findComment-6701172
I think I will have a car put back together (and hopefully still running).
I don't mind where and since I'm not organising it, it doesn't matter. If I had an issue with the organised location, I probably just wouldn't go.
I'm also curious to know how much cheaper Ultimate tunes would be. Last time we had a dyno day there, it was $50 each for two power runs (which I don't really consider cheap).
https://www.sau.com.au/forums/topic/417227-dyno-day/page/3/#findComment-6701447
if you wanted to "segment" the day perhaps stick with a Japanese car theme. That said thats gay so invite the world :P nothing better than seeing little bangers struggle to reach 50kws and then some crazy nutter hit 500+kws in the same day.
I would anticipate getting 3-4 supras on board if we're lucky.
couple big blown v8s would be cool too!
https://www.sau.com.au/forums/topic/417227-dyno-day/page/3/#findComment-6703771
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
