Guys as you know I have an r33 GTR and according to my tuner it's due for a fresh of oxy sensors.
Here's what I need help understanding..
I'm using r32 dumps which have an opening to suit 12mm sensors - I.e NTK OTD2F-1P and or standard.
From my understanding 33 and 32 use different type of sensors - zircona vs Titania . Would it be fine if I was to use Titania oxy sensors on my 33?
Btw I'm using a power fc
Any help appreciated,
Cheers
https://www.sau.com.au/forums/topic/417278-oxygen-sensor-dramas-r32-vs-r33-gtr/
You have two options...
The one mentioned above which I prefer,but takes alot more time to tune the low load/crusing section of the map which results in better fuel consumption if done properly or...
There is "O2 sensor reg." in the ETC. menu of the pfc which allows you to choose between r32 and r33 type O2 sensors.
If I remember correctly, off(+ sign) is r32 type. The info is floating around here....somewhere
Found the info. from Paul and its the other way around.....My bad,but as I said i just turn them off :)
apexi's official answer;
There is a difference in the o2 Sensor for these vehicles. (With or without internal register)
After tuning, please check () "O2 Sensor REGISTER" for BNR32, and NOT for BCNR33.
So off (+sign) is for r33 type sensors
turn off the o2 feedback and leave it off - tune around it
+1
always got better economy with it off and a good tune, and just leaving a dead sensor in there or a bung.
The factory O2 Sensors tend to fail more often in modified examples as well so better off just getting rid of the expense.
  • 1 year later...
Threads like this one are the reason why I keep coming back to SAU.
I have a late model BNCR33 engine in my early edition BNR32.
I installed an AEM wideband and it's constantly reading rich (14+). A couple of weeks ago, I checked the spark plugs and they were very filthy with fuel. I tried my best to clean them but a friend said I should completely replace them. I'm planning on doing that but I want to find out why my GTR is running so rich.
I think I tracked the problem to my O2 sensors via a mechanic that was doing some different work on my car. I have BNR34 VSpec dumps with BCNR33 O2 sensors installed on my BNR32 Skyline. I also have a Mine's ECU that's in need of a tune or change. :-(
Do you guys think that using a stock ECU and/or changing to BNR32 O2 sensors will improve my fuel economy?
Thanks for the clarification, Hadouken. If the spark plugs are filled with fuel, wouldn't that indicate a "rich" car?
Ido,
I don't have the stock ECU any longer. Is it possible to but a used one from the auctions and still have it work on my car?
Ido,
Yes you can buy a used one or a PFC... or a plug in Link or Vipec will go in the case inhabited by your Mines chipped ecu.
I think that's what he meant: "your gauge us shit."
Let me ask you guys something, is it possible to go on a 4-5 hour road trip in the current state my car is in? I have to drop off my vehicle at a friends place that's quite far
the wide band sensors can crap out too not just the gauge. hard call there....if you are worried i'd say stay off boost and you should be ok....but in the end its up to you. I'd re-check your afr's if you can...seems weird you'd be 14's and have fouling plugs...check your breathers and make sure your intake isn't all gummed up with oil vapour residue etc.
it should be pretty obvious when they don't work....the one we were using that was faulty would only read down to 11's before giving no reading.... you should be running around the low 12's to low 11's on boost....strangely your car is quite like my wife's car...bnr32 with bcnr33 motor.
Just to confirm my own thoughts? Doesn't the o2 sensor only work during lean cruise?
I thought the ecu only uses it at lean cruise (closed loop monitoring) where it looks for the rich or lean side of lambda.
that's why it flicks around 14.5-15.5-ish back and forth as it continually looks for and aims for lambda 1.
Then when you load the engine from cruise to accelerate it will give a solid afr and richen the more load increases.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
    • The stock manifold is "mostly" divided. The divider actually has a notch cut out of it where it would meet the divider on a twin scroll housing. I have no idea why. But whatever the reason, it would cause some cross talk when used with a twin scroll housing. People do put twin scroll housings onto that manifold. But I'm of the opinion that proper twin scroll internal gating is...not really possible at this scale. You'd be throwing good effort (ie $$) after bad, when you really should be doing something else. Notwithstanding that.... I am not sure what the idea that you are floating has to do with the difference in comp cover position caused by the highflow using a shorter length core than the stock Hitachi one. Can you clarify what you meant?
    • Majority of regulars are > 30. We all act at least 50. Definitely not friendly as we're all grumpy. 😛
