E85. It was your recommendation actually from a previous thread. I ditched the 34 as Roy said 33's are Iighter, so I bought a 33. Simon made good power with his 25 so I stuck with a 25. You said FP HTA3076 + 6boost so I went that way.
No good asking questions if you don't listen to the answers.
It's track only so will be pushed hard.
I'm keen too on results, keen to see what she'll make.
There's a built 25 with 6boost + FP 3076 about to hit the rollers.......
Should this have been interpreted to mean that results were going to be posted shortly - or should I start breathing again? :D
Sorry but you'll have to wait about 3 weeks. Turbo should land Thursday, then dummy fit for dump before all going off to Crave for some ceramic coating. First event is 2-3 March so got a bit to do yet before then.
That is cool :D
I forgot to ask, is your RB25 running upgraded cams? Plenum? And what size fuel system? Gotta set myself up for what to expect hahaha.
Tomei PonCams, FFP, minor port/polish, full supertech valvetrain with os exh valves, E85, twin pumps.....all the fruit required to be a fairly decent 25.
My budget build sort of got lost along the way.. :whistling:
No kidding. I hope it pays off! Should make good power, though I'm really looking forward to seeing the power delivery and hearing how it drives - it should be a bit of a beast.
If all goes to plan a friend of mine will have a decent result to contribute also as a comparison.
VQ25DET with FP3076HTA, .82 Tial Vband
Im helping a lot with the thought process and (like lithium) hope it works out well! LOL
Is this in a Stagea? I was hoping someone would do an engine conversion into something with a decent amount of room, without the cramped stock manifolds...
Should be interesting to compare to my results. Staying auto?
Can tell you its not in a stag but im gunna bite my tongue and let Jase tell the details :whistling:
Is going into an S15 with stock manifolds and Z33 6 speeder :banana:
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
