Rules:
  • No bouncing - Each rep is to come to a stop on the floor
  • No free falling - Each rep must be lowered to the floor in a controlled fashion - ie no lifting, then slamming it down
  • Belt use is ok
  • No straps
  • No gloves
  • Must be filmed - side on so we don't have to stare at your arse
  • Weight = 100kg - Yes that includes the bar you weirdos
  • Use at least 1 standard sized 20kg plate per side so the height from the ground is roughly the same for all
  • All reps are to be completed in one set
  • No swapping grip - if you start with a double overhand grip, that's your own silly mistake
  • No long rests between reps - Understand that in the upper range of reps you might take 3 breaths down the bottom before attempting another rep, that's fine, make them quick and do the next rep - no taking a smoko while your down there.
  • No Hitching - where you lift the weight to just above the knee, then kind of lean on your thighs and jerk it up instead of a smooth constant lift
  • No bar dip - where you are so tired and you get to a point where the bar stops moving upwards and kind of goes down a little before super powers allow you to pull harder
  • You can deadlift using conventional, sumo, stiff legged or whatever you want.
Winner gets to choose next event.
You can have multiple attempts
You have till End of January to upload your best effort.
Anything I've missed?
Perhaps to cover the 2 ladies we have who might want to play we can make it 60kg for the girls? ie the lightest we can make it to have the bar start at the right height.
Edited by TTT
https://www.sau.com.au/forums/topic/417941-deadlift-challenge/
  • Replies 297
Might try it, without video, LOL. (null & void I know, but hey, I dont do "selfies")
Will have to go SL-style while wearing full lockable knee braces. Good motivation to pickup - no pun intended - deadlifts again.
edit: ^ females @ 60kg. males @ 100kg. Maximum amount of reps. fact is the lighter guys should have it easier with future challenges, such as dips.
100 kg including bar?
Are you f**king serious?
Great idea but I really think it should be done at a % of bodyweight. The bigger and heavier guys clearly have an advantage and this clearly excludes most females (unless they train at PTC!).
There are 2 females here.
and I also stated that if they want to to it they can use 60kg
If you want to make the next challenge a % of body weight, that is fine.
All you have to do is win this one.
K go!
Sounds good mate.
now you just have to win this one to make it so.. :D
Dick. haha. I'll give it a shot tonight, but given how I feel right now I'm not sure it'll go too well :P deadlifts are first up though, so who knows. Unfortunately I know I can't WIN this round given I couldn't match Joey's effort, however bodyweight considered I'll do pretty damn well.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
