I upped a guys PB by 20kg in 5 minutes by raising his hips up
He'd been deadlifting 190kg for nearly a year, 5 minutes later it was 210kg
He was trying to squat the weight up
Check out Martins vid, he pulls 281kg@79kg
Deadlifts are a back exercise
you are right. I thought he was talking about too high vs normal. My vids are on the bit too high side to work my back more , I remember going a lower when going for heavy lifts but, still not squat level. At least that's what I remember doing been a long time. I'm not ready to go real heavy again yet.
Edited by rev210
  • Replies 297
Trozzle - 14
Rev210 - 20
GTR_JOEY - 19
JEPPE - 20 but no vid
R32 Gojirra - 15 but no vid
Birds - 10 but no vid
Added myself to the list until I get a vid up. Will try for one tomorrow.
I do have a vid on my phone but im computer illiterate (im old and shit lol) and dont know how to upload off my phone. Cant do it from work (restrictions) and dont have the net at home (lame i know lol).
Didn't someone do 25?
Added grumbles now, was looking forward to actually pushing it with the squats, 20 still had heaps of room left for more. Got a full 10 out the other day at 72.5 with room so wanted to increase that too. Guess I'll be doing this contest who-knows-when the shoulder is better.
I was... but I'm in the middle of a program for GPC states and TTT scared me by telling me not to hurt myself... I should've done it today when I trained...
I won't win anyway, I HATE deadlifts for reps... anything over 5 sucks balls lol
He just scared you so that so he can beat you and make sure he controls the next challenge....
I don't think it's the reps over 5 you 'hate' , so much as the rest in between sets that your oldman-itis 'likes'. After all , add those 5 rep sets up and you may as well just keep going for 15-20 in a row? ha ha.... just do it and compete . It's more win!
Bit of a noob question...is it normal to have pain after deadlifts? I usually only get it after doing sets of high weight or 1RMing, so it's related to heavy exertion...and it disappears after about 15-20 minutes. I can't tell if it's muscles aching or joints, so am a tad concerned. Have always had it, since doing deadlifts. I ask my friend if he feels the same after deadlifts and he refers to a tightness in his back muscles...but I'm not sure if we're talking the same thing, cause this makes leaning over the basin to wash hands at the end of a session quite painful.
I have had back issues in the past due to bad posture at work, so get cautious when it comes to back pains. And no other exercise gives me that feeling in the area being worked.
I started a DL challenge over on my forum, 2.5 x bw for men and double bodyweight for women
Nina went first and managed 120kg x 10@58kg
I'll get a few of the guys to do some next week, mind you, Zoran, Spiros, Rocky, Mick and Max cant get close, only Martin would beat her 10 at 2.5 x bw (men)
Is it Normal? No.
Is it normal for me? Yes..
lol
Don't be too worried mate.
I'd say you probably didn't hold as tight for one rep or perhaps hyperextended a little at the top on a couple of reps.
When you get a chance, lay on your back and bring your knees up until your whole back (including lower back) is flat on the floor.
lay like that for 5 minutes so it all settles.
nights sleep and you'll be fine.
This is also the reason I don't like lots of reps.
you get tired and sloppy.
I've got one more week of 12 reps and then down to 7 weeks of 5 reps, then 2 weeks of 3s, then 1 week of doubles, then it's time to Beat Nick!
lol
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
