Would have to be 1k wouldn't it? I'm not really sure what mild steel prices are. Stainless would have to be what 1.2-1.4k for a decent cat back 4"? I really have no idea but just a estimate.
  • Replies 73
$700-800.
Be nice do have a custom centre and rear muffler made that actually work, so we can run these big systems and not worrie as much about the cops.
My tomei system, flows awesome but it's stupid loud.
If I was to do a minimum of 5 systems using 4 inch mild steel with resonators and mufflers I could do them for $1200 each with flanges, bolts and gaskets.
4 inch mufflers and resonators aren't cheap
By comparison a 3.5in system doing 5 of them I'd say $880-990.
Does anyone have any actual knowledge of what effect (if any) it would have on an engine to have the cats staggered on a twin system? By that I mean having one cat slightly closer to the engine than on the other pipe to allow them to fit under the car better?
Like this picture (best photo I could find!)-
I tried Googling but couldn't really find any info.
Any effect if any would probably be negligible.
It wouldn't hurt to stagger the cat’s so there equal distance from the turbo’s – that would ensure all things are indeed equal.
Edited by R31Nismoid
I can't remember what underside I saw, but there are some cars in the US doing it (modified). Can't see it as a problem as if you put them side by size "technically" they aren't event anyway given the front turbo is further away, and such setups work without issue. So you are effectively making it better.
Just ensure there is a cross over pipe somewhere if doing separate CATs/pipes.
Good point, I stupidly didn't think of that! In theory that makes it perfect! The offset would be nearly identical.
I remember when I was a tech at Holden when the whole crossover pipe thing came along. Late 90's early 00's from memory. If it only makes it a bit quieter then it's worth it.
Not so much the sound level, it's more the fact that going 3 cylinders per pipe, without a X-over, sounds really bad in a lot of cases.
Last car i heard like that didn't sound like a "RB" at all really. It was weird.
pretty sure there are some jap twin exhaust that don't have a crossover pipe....can't recall how good or bad they sounded though.
Edit: just checked a few u-toob vids and they sound like crap. I have always wanted a twin 3"...but I think a single 4" will do.
Dual 3" exhausts is the same as having a single 4¼" exhaust.
Can you post some links Charlie? I must have shite searching skills as i couldn't find any!
  • 1 month later...
After reading this article http://www.modified.com/tech/modp-1102-exhaust-test-tech/
It seems like there could be a gain by going 3.5 inch. I already have the trust extension pipe which are 2x70mm. so to get perfect sizing, I should get myself a 4 inch cat-back to match the 2x70mm total exhaust diameter.
However, my setup is a RB26 with stroked 87mm piston and -5 with cams and all the supportive mods you could expect.. My cat-back is 3 inch right now. So, going 3.5 is quite easy, theres tons of aftermarket BUT theres very few 4 inch catback..
Whats your thought, anyone saw gain from 3.5 to 4 inch ? Should I really concentrate on having both the downpipe and catback ''flow-matched'' or simply stick in a 3.5 instead of my 3 inch and call it a day ?
P.S: I'm also keen about a 3.5 or 4 inch group buy in stainless steel!
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
