yes it could be fitted, but it won't run. the rb30 bore is the same diameter as the rb25, but the stroke is 13.3mm longer, so the piston will be 13.3mm lower at TDC than with the rb30 crank. so the compression with me drastically lower than standard (you'd have higher pressure in your tyres than in the combustion chamber). of course you could overcome this with aftermarket conrods (expensive), but then all you would end up with is a rb25 with a taller block (won't have 3L capacity) and no VCT. so you would spend a heap of money to make a stock rb25 worse than stock
A 30 crank in a 25 block would be interesting in terms of keeping the same engine appearance engine number etc, but the cost of machining along with custom rods and pistons would kill the idea quickly.....
using a 30 crank with a 25 head has been discussed on this forum before (many years ago though). then general consesus was that, other than the cost, it would be a bad idea as the conrod length to crank length ratio wouldn't be very good, reducing torque and increasing the chance of breaking conrods, etc, because at 90 degrees ATDC the conrod is going to be at more of an angle than with the stock (longer) conrod, meaning it has much more sideways load on it
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
