Selling my 1995 R33 GTST, 25/30, 500HP, 380KWATW (safe 98 tune)
Fully engineered and registered till SEPT 2013 for NSW
Motor built by UNIGROUP ENGINEERING using best parts available
Gearbox built and modified by AWARD
Nismo twin plate coppermix clutch
Nismo dash
R33 GTR rear end
R33 GTR rims, Hankook RS3 tyres
R34 GTR front seats
Bonds half cage
White Line sway bars
Adjustable camber arms
Bilstien shocks
Lots of stuff done, you need to have a look.
From some Skyline gigs vvvvv
Best R33 Modified winner at the Shannons Skyline Nationals 2012
Wakefield Class B winner at the Shannons Skyline Nationals 2012
Import Monster SAU NATS Modified 2WD Class, quickest 800mtr
Import Monster SAU NATS Modified 2WD Class, Highest speed 800mtr (245kph)
Selling as the kids are costing me a fortune in dental and schooling and this toy needs to go.
$16,000 ( Ive put maybe 50K into this thing)
Whole car only, Im not parting it out so dont ask, and no holdsies.
If you are looking for a car that can lap Wakefield, run a low 11 sec quater and drive to Queensland for for a cruise then this may be what you are after.
https://www.sau.com.au/forums/topic/418712-r33-gtst-2530-500hp/
Engine specs
Head RB25
Custom exh cam
Drain backs/vents
Drilled out oil returns
RB26 cam covers with MINES baffles
External oil feed (1mm restrictor)
ROSS CAS
Block RB30
JE pistons
Eagle rods
ARP studs
ACL bearings
Hi volume race sump
TOMEI oil pump
EARLS oil pressure regulator
ROSS balancer
Bolt ons
Custom steam pipe exhaust mani
TO4Z
TIAL gate
Greddy copy inlet
600 x 400 x 100 x 3" IC
3" IC pipe
QF45 throttle body
4" intake
Blitz BOV plumbed in
Alloy FENIX radiator
LINK ECU
Limited to 7500
Ishift set at 7200
LINK 7 bar map sensor
GREDDY EBC
Motor and accessories was all balanced.
Thanks
Wow. Can't believe you are selling but you gotta do what ya gotta do!
16k for an awesome all rounder is worth every cent as Dave said.
This car is a cracker, it is a great weekender with track potential.
Best of luck Mark and if I had an extra car hold and the coin I would have transferred the money already.
The Bonds cage is a bolt in, rear seats and belts will go with the car if the new ownwer wants to remove the cage and fit the rear seats back in.
Do not make me go into the whole wife spiel. You sell this and you will not be able to afford to replace it for another decade at minimum. Instead garage it, pay for the dental and the schooling and pick up where you left off with smiles forever more.
If I had 16k I would buy this off you and give it back for free, you just need to keep it that bad.
Car was viewed last night and is on hold for today only.
Spares that will go with the car when sold if you want them
A pair of R32 GTR rims with Mickey Thompson 255/50 16 ET street drag radials;
A set of std discs;
Pair of rear king springs;
Some boot trims;
A spare RPM racing harness;
A fire ext;
A pair of OMP gloves;
A RPM balaclava;
Some new silicon hoses;
A KBC full face helmet;
First aid kit;
And some oils and fluids.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
