Selling my 1995 R33 GTST, 25/30, 500HP, 380KWATW (safe 98 tune)
Fully engineered and registered till SEPT 2013 for NSW
Motor built by UNIGROUP ENGINEERING using best parts available
Gearbox built and modified by AWARD
Nismo twin plate coppermix clutch
Nismo dash
R33 GTR rear end
R33 GTR rims, Hankook RS3 tyres
R34 GTR front seats
Bonds half cage
White Line sway bars
Adjustable camber arms
Bilstien shocks
Lots of stuff done, you need to have a look.
From some Skyline gigs vvvvv
Best R33 Modified winner at the Shannons Skyline Nationals 2012
Wakefield Class B winner at the Shannons Skyline Nationals 2012
Import Monster SAU NATS Modified 2WD Class, quickest 800mtr
Import Monster SAU NATS Modified 2WD Class, Highest speed 800mtr (245kph)
Selling as the kids are costing me a fortune in dental and schooling and this toy needs to go.
$16,000 ( Ive put maybe 50K into this thing)
Whole car only, Im not parting it out so dont ask, and no holdsies.
If you are looking for a car that can lap Wakefield, run a low 11 sec quater and drive to Queensland for for a cruise then this may be what you are after.
https://www.sau.com.au/forums/topic/418712-r33-gtst-2530-500hp/
Engine specs
Head RB25
Custom exh cam
Drain backs/vents
Drilled out oil returns
RB26 cam covers with MINES baffles
External oil feed (1mm restrictor)
ROSS CAS
Block RB30
JE pistons
Eagle rods
ARP studs
ACL bearings
Hi volume race sump
TOMEI oil pump
EARLS oil pressure regulator
ROSS balancer
Bolt ons
Custom steam pipe exhaust mani
TO4Z
TIAL gate
Greddy copy inlet
600 x 400 x 100 x 3" IC
3" IC pipe
QF45 throttle body
4" intake
Blitz BOV plumbed in
Alloy FENIX radiator
LINK ECU
Limited to 7500
Ishift set at 7200
LINK 7 bar map sensor
GREDDY EBC
Motor and accessories was all balanced.
Thanks
Wow. Can't believe you are selling but you gotta do what ya gotta do!
16k for an awesome all rounder is worth every cent as Dave said.
This car is a cracker, it is a great weekender with track potential.
Best of luck Mark and if I had an extra car hold and the coin I would have transferred the money already.
The Bonds cage is a bolt in, rear seats and belts will go with the car if the new ownwer wants to remove the cage and fit the rear seats back in.
Do not make me go into the whole wife spiel. You sell this and you will not be able to afford to replace it for another decade at minimum. Instead garage it, pay for the dental and the schooling and pick up where you left off with smiles forever more.
If I had 16k I would buy this off you and give it back for free, you just need to keep it that bad.
Car was viewed last night and is on hold for today only.
Spares that will go with the car when sold if you want them
A pair of R32 GTR rims with Mickey Thompson 255/50 16 ET street drag radials;
A set of std discs;
Pair of rear king springs;
Some boot trims;
A spare RPM racing harness;
A fire ext;
A pair of OMP gloves;
A RPM balaclava;
Some new silicon hoses;
A KBC full face helmet;
First aid kit;
And some oils and fluids.
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
